gray G-100 amplifier
Spyedar
Handle: Slowpoke/1374
Real Name: Chris
#412068
Post by Spyedar »
Hello there, I'm new to this forum and I have a Gray G-100 amplifier good transistors, but it's only putting out 70 watts on high on low on AM and SSB. Anybody got any ideas?
Bozo
Owner
Owner
Handle: Bozo The Clown
Real Name: James Wadsworth
Antenna: Monkey Made MM9
Radio: General Lee Radio
Re: gray G-100 amplifier
#412069
Post by Bozo »
Spyedar wrote: July 18th, 2024, 4:40 pm Hello there, I'm new to this forum and I have a Gray G-100 amplifier good transistors, but it's only putting out 70 watts on high on low on AM and SSB. Anybody got any ideas?
Welcome to the forum, @Spyedar! 😄
Here's some troubleshooting ideas...
  1. 🔋 Check Power Supply Voltage: Ensure it's correct and stable.
  2. 🔗 Inspect Connections: Secure and in good condition.
  3. 📡 Antenna System: Properly matched and working.
  4. 📶 SWR Check: Measure and ensure it's within limits.
  5. 🧰 Bypass Capacitors: Check for damage.
  6. 🔧 Transistor Biasing: Verify correct biasing.
  7. 🚀 Driver Stage: Ensure it's functioning correctly.
  8. 🔍 Internal Components: Inspect and replace faulty parts.
  9. ⚡ Relay Contacts: Clean if dirty or corroded.
  10. ❄️ Cooling System: Ensure it's working properly.
Hope this helps
Donate here
#412072
Hello Spyedar,
Welcome to the forum. There are so many factors in getting a correct power reading, SWR, coax, antenna or dummy load, etc. I will say that sounds about right on output, usually on the "high" setting with 4 watts input, it won't have very much swing modulation, on "low" the output is lower but swings more giving the radio better modulation.
Gray made very good amplifiers in the day but I will conclude that amp is over 50 years old.
