CBRT has been
Cobra 25 LTD Classic Mfg.Nov.22 low audio
This forum is for general discussions, and you are welcome to post in this forum if you are not able to find the right place.
WIRADIOOP
Handle: Jrcharles
Real Name: Jamie
#412100
Post by WIRADIOOP »
Good day all,
First I cannot find any schematic or service manual for the radio.
Anyway, Here's the issue. It has low RX audio only, both speaker and Ext.Speaker. All other functions work. The s-meter is also reading low. So it must be and issue before the meter. I am assuming it is possibly an AF amp? I don't think its a cap, its a relatively new radio. The board # is KEPC-1111-X3.
Does anyone have access to schematics or service info? Or does anyone have another thought on where I'm losing the AF gain???
Thanks a lot guys. I sure do like this site.
Jamie
Re: Cobra 25 LTD Classic Mfg.Nov.22 low audio
#412101
How is the audio if you receive a S-9 signal?
WIRADIOOP
Handle: Jrcharles
Real Name: Jamie
#412108
Post by WIRADIOOP »
Greg,
Well, I'm going to say weak. If the skip is coming in strong you probably wouldn't notice it. I have a 2nd good radio(same) and the volume control on the weak audio radio in 2:1. Meaning, weak audio radio needs to be 100% and the good radio at 50% volume to get similar results.
hope this helps.
It maybe the audio Chip?
Jamie
WIRADIOOP
Handle: Jrcharles
Real Name: Jamie
#412123
Post by WIRADIOOP »
Greg,
Update.
I just injected the s9 signal (50uV) and the meter reads as such, but the volume is low. So where am I losing the volume? Anyone.
Jamie
