Need mic unknown information.
• Page 1 of 1
- Windwalker
- Moderator
- Handle: Windwalker
- Real Name: Clifford Stewart
- Call Sign: KD8QHS
- Radio: Cherida S890
Post by Windwalker »
I have a 10 - 12 meter Chinese radio. The mic is bad so I want to get a new one for it. It is a 4 pin mic. The problem I am having is that I see many 4 pin mics on Fleabay and such. Prewired with descriptions that say they fit most all 4 pin mic radios cb and ham. While looking at many different mics I see noise cancelling, standard coffin type mics and power mics. The specs on these mics have different ohms. Commonly 500 or 1000 ohms.
So my question is 2 things.
1. How do I find out how many ohms I need
2. What will happen if I use the smaller or larger ohm mic.
The info in the listings is not clear as to whether a noise cancelling mic OR a power mic has the higher or lower ohms. ...
I have no way in finding out in a manual for the radio what it requires... The radio does have the power mics in the software and can be set for each mode. Am Fm USB LSB and I think cw is preset standard as it dosent need a mic for that function or mode.
Some of the mics I see say 10 meter SSB radios and others say nothing but general info.
Basically I just need a regular mic but I dont know what to buy even though they are not a lot of money.
Due to the wide variety of mics and partial info or descriptions is making it confusing.
Please help
WW Global
Please help
WW Global
- eyecue
- Handle: eyecue
- Real Name: Brad
- Antenna: sirio
- Radio: Uniden, SBE, Motorola, GE, Connex, RCI
Re: Need mic unknown information.
Simplest way is to use a scope and signal generator at an audio frequency. inject the signal into the radio and set the amplitude on the scope to some value you can read. Now insert a potentiometer in series with the input and measure again and adjust the potentiometer till the scope shows 1/2 of the amplitude of the original signal. Remove the potentiometer and measure its resistance. That is your impedance.
- Windwalker
- Moderator
- Call Sign: KD8QHS
Thanx eyecue.
The problem is that I dont have scopes and such. I do know a certain amount about electricity and MOSTLY I understand what you are saying I just dont have the ability to do it.
My electrical tools is limited to a multi meter, hand tools and an Non Contact Voltage Tester.
That said ////////
Could I use my Ohm meter to test the mic but which pins would I use. Or would I have to take it apart and OHM out the speaker itself. I really dont think the speaker would have 500 or 1000 Ohms. Especially since it is so small in size.
Anyway what would happen if I used a smaller or larger amount of Ohms.
This makes me wonder if Power Mics have variable Ohms through the ability to adjust the amount of audio to prevent squeeling.
I think many people who replace a microphone dont even pay attention to these specs and just go by the number of pins. Thats not good enough for me I want the right stuff to get the right audio and not possibly damage the radio if even over time. Its a special radio to me...
That said ////////
I never noticed a lot of difference in most replacement microphones, you would be more interested in the microphone's frequency response.
- Windwalker
- Moderator
- Call Sign: KD8QHS
Yes I can understand that. But this 10-12 meter radio has the power mic in it. This is not an SDR radio but it does have software in it along with the regular stuff similar to a Cobra 29. It has a menu driven software section so to speak. It does have the power mic in the radio but it also has settings like TOT, SWR safety, Tone generator and a total of 26 different software options. Along with the usual squelch, RF Gain etc. I really wish I could find out what the higher or lower Ohms do to the radio. And the mic has a channel up and down button and a mute button. Im gonna investigate some more but I may have to buy 2 mics with the different ohms and get radio checks to see what works best.
Okay, the stock mic uses diodes for the up/down function and the mute is just a switch in the audio lead. It can be wired up but I'm not familiar with radio. I did back a while add the micro buttons to a Astatic Red Devil mic for a AT-6666 but after using it a couple weeks, sold it to another as the AT-6666 didn't need amplification.
- Windwalker
- Moderator
- Call Sign: KD8QHS
I think Im gonna contact the factory in China and see what they say.
This is a very unique radio and I want to keep it alive !!
- Windwalker
- Moderator
- Call Sign: KD8QHS
Jet I am looking at Dynamic mics. The radio has the power mic in it factory. Noise cancelling is also wanted. Im gonna try a good mic and hope for the best !!
WW Global
WW Global
• Page 1 of 1
Jump to
- Welcome and Community
- Skip Shooter's Paradise
- ↳ General Discussions
- ↳ Watergates & Videogates
- ↳ Shooting Skip
- ↳ Hall Of Fame
- ↳ Journal
- Radio Help
- ↳ Intro To Radios 101
- ↳ General Questions
- ↳ Base Setups
- ↳ Competition Rigs
- ↳ Charging System
- ↳ Mobile Setups
- ↳ Antenna Help
- ↳ Microphone Info
- ↳ Radio Modifications
- ↳ Sideband (SSB)
- ↳ Tube Radio Equipment
- ↳ Other Technical Questions
- ↳ Miscellaneous Radio
- Buy / Sell / Trade
- ↳ For Sale Area Rules
- ↳ For Sale Area
- ↳ eBay Shopping
- ↳ Amazon Shopping
- ↳ Trade Equipment
- ↳ Wanted Radio Equipment
- ↳ Positive Feedback
- Off Topic
- ↳ Miscellaneous Chat
- ↳ Computer Help
- ↳ Signature Test Area
- The White House
- ↳ Ask Marv
- Home
- All times are UTC-06:00
- Cookie-Settings
- Delete cookies
- About us
- Downloads
- Contact us
