Dodge ram 2500 install
- MD115
Hello folks,
I want to instala a cb on my dodge ram pickup.
First I have to decide between a galaxy 959 or Just a cobra 19 iv.
Second I have a k40 antena but something hapoend inside, has a resistor but its not replace le or some one has?
The Second question was about the antena, what kind of antena you do the Best perdormance, if I DONT want to use a wip.
295 antenna Verified
- Moderator
Hello MD115, I like the 959 because it has more features such as sideband . It also has a great noise filter but with all these features it is a full size radio. If your not concerned with the extra stuff the 19 is a compact radio and a bit more rugged in my opinion.
- MD115
295 Thanks for the comment.. Y I was wandering if in the truck Will need ssb, whsts your experince? No do you use ssb on a mobil? If not a definí ve Will go with the cobra 19 because of the small size and notingh to break. El maybe I Will put a little amo of 100 wats Just to kick a little bit the power.
Can you comment on the antena? It my main concern.
- nk14zp
Cant beat a 102 whip.
- MD115
You are absolutetly rigth, que But i dondt want to end electrified. The issue is my ram is tall al ready plus a wip im going to hit everitingh. Gime your Second Best choise
JetSetter Verified
- Moderator
How about something like a Predator 10k. Make sure you check out are sponsors for the best price. And maybe you could match that with a nice KL-203 amp. Just a thought
"822" Were Alive and Kickin'
From the land of Lincoln
- nk14zp
On my lifted 3500 I run a K40cbmax on the cab protector.
- MD115
I like the k40 but mine has a problem, and I manage to take que it a part and in the base has like a resin it doesent open an inside has like a resistor. I thinks there is the problem but if I hammer the resing I thing the antenna is not going to work anymore. Any thougths?
- nk14zp
Mine has an air coil. My next choice would be a 4 foot fiberglass from the truck stop.
Not sure if it is a magnet mount or permanent mount, please specify. The K40 doesn't have a resistor but a capacitor to keep the impedance close to 50ohms. The problem is probably moisture/water in the coil load enclosure. The only other problem I have ran across other than burning them up was bad coax, say it has been pinched in a door jam.
Depending on the year of your Ram will negate where to mount the radio, my Ram is an 2004 and my radios are mounted on the transmission tunnel. I will be changing this soon to a radio that has a removable head unit and that be installed on a gooseneck seat bolt mount.
- MD115
Ram is 2009 and the k40 is permanent. I jsut check the antena and the continuity on the multimeter tester is shorted. I thinks this is not ok.
- nk14zp
CB ant center,VHF right side of rack, Screwdriver right side of bed.
- Moderator
Dont really know to much about that antenna.I run a wilson 500 for my stryker 25mc and thats enough for my 20 watts and i still talk all around the local area. As far as sideband is concerned it a personal preference. If your interested in talking am only and mounting space then the cobra will do just fineMD115 wrote: ↑September 28th, 2019, 8:51 am 295 Thanks for the comment.. Y I was wandering if in the truck Will need ssb, whsts your experince? No do you use ssb on a mobil? If not a definí ve Will go with the cobra 19 because of the small size and notingh to break. El maybe I Will put a little amo of 100 wats Just to kick a little bit the power.
- MD115
Its a New istall. I can Mount it where its more efective. As the high is an issue maybe Will be on trunk bed, dentered near the back of the cabin. What do you think nk14zp
- MD115
I think im convinced to try the cobra First now. It much smaller and can make changes of place relative easy and usted for a couple of months. About the antenna I like the 10k sugestión and im going to try it. I aprecia te the time you and the guys have taken in to this.
JetSetter Verified
- Moderator
Check these out also. There from our sponsors
[Please login or register to view this link]&
- Gunner357
I vote P10KBeachbum24 wrote: ↑September 28th, 2019, 10:27 am How about something like a Predator 10k. Make sure you check out are sponsors for the best price. And maybe you could match that with a nice KL-203 amp. Just a thought
Yaesu FT920 (KE8PSI)
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Homemade Dipole base antenna
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
- MD115
Thanks Gunner for the comment. Have a good one. Will look on sponsors web page to see how much is it.
- Gunner357
Heres my Ram its only a peanut Ram wish I had My 2500 diesel back
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
