cobra 2000 gtl
- RedBaron324
cobra 2000 gtl
My Personal Cobra 2000gtl has no TX.. well very very little... can hear it on a radio real close by on SSB, and just a slight hum on AM, had no Rx either,did a complete recap and got Rx back, the Tx is baffling me, changed out the 1307 final to a 1969, still no Tx... Heeeeellllllpppp! lol
- Hawkei1967
- Mud-Duck Sr.
No transmit in any mode, AM/USB/LSB?
- RedBaron324
No sir, well as I said, you can faintly hear it on a radio roughly a foot of 2 away.
- Hawkei1967
- Mud-Duck Sr.
Clean the Bias adjustments in the driver/final section, then readjust bias according to specs.
Test it out.
If you still have same issue, then replace the 2 bias electrolytic caps in the driver/final section, readjust bias and retest.
If you still have no transmit, then check collector voltage on driver, then on final. Replace faulty driver or final, readjust bias, test again.
Test it out.
