Lighted toggle switches
Beachbum24
Radio: Galaxy DX959, 29LTD
Antenna: Browning, PAT-12
Cell Phone: 331-200-0775
Post by Beachbum24 » Friday, 13 July 2018, 12:43 PM
Hello CBRT, I did the channel expansion on my Galaxy DX959. What i'm wondering, is it possible to use a spst lighted switch for this. I ask because when i put my test meter to the pins to figure the wiring, no matter how i do it, there will be power, which seems it would kill my radio. Just wondering if anyone has used these before for this application. Or maybe i should be using a spdt switch. Which i think i do.
Peace all :dance:
"822" Were alive and Kickin'
From the land of Lincoln
Beachbum24
Re: Lighted toggle switches
Post by Beachbum24 » Friday, 13 July 2018, 13:37 PM
I have a cure, going to hook up a power supply to it and test the volts across the pins. Just to make sure no volts are going to my radio
Post by MDYoungblood » Friday, 13 July 2018, 13:46 PM
I think the lighted SPST switches will only work when the make/break poll is a ground. You don't want to be suppling the mod with a 12v source, it will fry the PLL circuit. now on the other hand using a DPST switch, one half is the 12v souce and a ground the other can switch the mod.
Beachbum24
Post by Beachbum24 » Friday, 13 July 2018, 14:13 PM
I figured i had the wrong switch, just wasn't quit sure which one i needed. And that's what i was trying to avoid, volts going to the pll.
