Hummer wrote:Wow thats amazing, wish my setup could do that. My 150ish watts are nothing compared to that, How much keydown time do you do with that? I hear alot of people running mauls and they stick with acouple of minutes of keydown time.... Is that true with the keydown time? Heat causes stress so i would guess so it would be kept to a minimum.
The 16-pill does get hot quick. You could probably fry a egg on it after just 10 minutes of talking...And just sitting still talking the motor compartment gets hot quick too from the heat off the three alternators. (and the fact it's been over a 100 degrees here in the Dallas area now almost everyday probably has something to do with it)
But, I have sit and talked for quite a long time with everything in cooking-mode and so far not had any problems...I am thinking of getting some bigger fans tho for the 16 pill, because the fans that are in it now, are actually the same size as what is in my 6 pill Davemade (which doesn't get hot, but it's also less than half the size of the 16)
Once I get some bigger fans, I'm hopping it wont heat up as much...
