feedback through stereo
pathfinder
Post by pathfinder » Tuesday, 04 March 2008, 9:24 AM
I drive a sterling daycab , and I run a General lee , no amp , I use a wilson 2000 antenna , mounted behind the cab.
I just replaced the coax and the center stud on the mount , my swr is under a 1.5
I get real bad feedback through my stereo when I transmit , I replaced the factory stereo with a sony explod , it has the input jack in the front for my Ipod or satellite radio.
I do use the talkback and run just a small amount of echo , and I use a motorola external speaker , that sits on the dash right next to the radio.
does anyone know what might be causing this ? or how I can fix this
bullet
Post by bullet » Tuesday, 04 March 2008, 9:40 AM
I think it my be modulation. I come over my stereo so bad I have to turn it off before I talk, but I have a heater and I like where the modulation is set. If I turn the mic gain down It does not come though the stereo.
linx
Radio: 2 tin cans + string
Referrals: 6
Post by linx » Tuesday, 04 March 2008, 9:42 AM
turn your stereo down :p that's free talkback!
i leave my stereo on 'aux' and leave the volume turned down. i come through my trucks speakers. sounds neat. if i turn the volume up on aux, it'll squeel.
if you're running a strong radio, ya may just have to turn your stereo off.
VOTE FOR CBRT TODAY!
CBRT ON TWITTER!!!
My Twitter Too
pathfinder
Post by pathfinder » Tuesday, 04 March 2008, 9:55 AM
thanks , that just answered my question , I do have the stereo on AUX , all the time , and I do normally turn the stereo off while using the radio, just wanted to make sure it wasn't a problem with the radio.
thanks guys
TwentyTwo-Zero
Post by TwentyTwo-Zero » Tuesday, 04 March 2008, 10:15 AM
Depending on where the RF is saturating the stereo you may be able to eliminate bleeding on the speakers by putting ferrite beads on the speaker wires as close to the speaker wire terminals as possible. Also, shielding the inside of the speaker enclosure (if appicable) with aluminum foil or copper shield foil may help.
Save Your Money, Don't Go To The Show
And Don't You Eat That Yellow Snow...Frank Zappa
WR0220 Washington State 38LSB
CPI • Cobra • Icom • Yaesu
Pocono Redneck
Post by Pocono Redneck » Tuesday, 04 March 2008, 11:26 AM
My General Lee was causing similar issues---I turned down the modulation adjustment pots (VR12 low power and VR14 high power) just a skosh and those issues went away--and it's still a loud gluteus maxims radio.
Keystone 7-6-2 said that!
Buckshot
Post by Buckshot » Tuesday, 04 March 2008, 11:36 AM
Is your general lee hooked directly to your battery? Is your location of antenna area grounding back to radio (battery.)These are add'l known issues & problem solvers.
289/B.S. WI.
whipsnapper
Post by whipsnapper » Tuesday, 04 March 2008, 14:54 PM
I have the same problem with the Sony Xplod radio in my Nissan pickup. I know I'm not over-modulating, and it doesn't do it in my Chevy with a Pioneer radio. I just turn the radio off when monitoring the cb. You could just turn it down, but it definitely sounds worse than I actually sound on the air. The coax is run nowhere near the power or speaker leads for the Sony radio. I haven't tried really figuring it out, I just figure it's the older Sony radio. It doesn't bother me though.
Interesting that they're both Sony radios (mine and yours). Mine doesn't have an aux input and will bleed-over whether in FM, AM, or CD mode.
pathfinder
Post by pathfinder » Tuesday, 04 March 2008, 20:25 PM
I have the radio hooked up to the binding post on the dash , the antenna is not grounded other than what the mount provides.
Users browsing this forum: Majestic-12 [Bot] and 3 guests
