connex cx33hpc1
connex cx33hpc1
hello, does anyone have information on the conversion to 11mtrs on the Connex CX33hpc1 ? the proper way not the one that doesn't work.
Re: connex cx33hpc1
Remove the speaker side cover to expose the circuit board components. With the knobs to you in the front center of the board is a jumper array of 6 pins, (2 rows of 3 pins). Move the jumper to the back 2 pins, center and right leaving a pin exposed to its left. Take should do it.
Post Merge Complete
Added 5 days 1 hour 13 minutes 54 seconds after previous.
???? Did it work, curious mines want to know!
Post Merge Complete
Re: connex cx33hpc1
thanks for the help 1st of all, it was a beast but I got it, for some reason the 4 times I tried it the radio would not take, it would receive on 11 but would not tx, so I cycled the power several times and said I will give it one more try, so I took the pin plug out and reset it into the specs you sent and whooola it works and works well, I am not sure why it didn't work the 1st 3 times, maybe I may have reversed the pin plug or needed to cycle the power fully disconnecting it from the power source.
Re: connex cx33hpc1
Glad you got it working, I hear it is a nice radio with excellent receive. A word to the wise, you should always remove any radio from a power source before touching any inside components unless you are using non metallic tools.
