Texas Star 667V only produces 300 watts Bird
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
Re: Texas Star 667V only produces 300 watts Bird
Stackpoles? Do you mean transformers? Hopefully no one changed windings. I was referring to the round yellow piece. That is a combiner. Underneath it it has a 100ohm resistor. Looks discolored maybe. If it is. That is a sure sign of an imbalance of the 2 pill sections somewhere. Hard to tell though from picture.
[ Post made via iPad ]
- Handle: Mr 231
- Real Name: Mr. 231 in the Carolinas
- Antenna: Sirio 5000
- Radio: President McKinley
Yes the transformers. (Texas Star calls them "stackpoles"). And yes I think someone did change the windings on T2 of the driver (collector side of the MRF454 - I counted 2 turns) and T3 Texas Star says it's supposed to have 3 turns - I counted 2 turns. T5 also TS shows 3 turns but I counted 2.
- Handle: Mr 231
The resistor does have some brown on the ends that flakes off when scratched. I'm thinking it's just flux. The center doesn't appear bad. Should I unsolder it and ohm check it?
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
No if it's just flux and no signs of heat in center. It should be fine. Have you put the driver back to stock yet?
- Handle: Mr 231
No I don't have another pill for it
[ Post made via Android ]
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
To much work to try explain how to check driver or even bypass driver to just run 4 pill section and see what ya get.
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
Actually I meant Tune driver.
- Handle: Mr 231
I was actually wondering how you would bypass the driver. I had a few tell me I'd be better off running it as a 4 pill. But I don't seem to find anywhere on the internet where it shows how to do this.
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
Have to disconnect input and output of driver. Then where the input used to go to driver, use rg316 coax and run a piece from the variable to input of 4 transistor. In a nutshell.
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
I'll have to look at 667 I have here, but I think on the 667 the changed the turns on input side of 4pill/ transistor section due to higher drive levels.
- Handle: Monk
- Real Name: Monk
- Antenna: none
- Radio: midland
I have a Motorola RF devices book and it says the MRF454 is a direct replacement for a 2sc2290.
I've never put the spec sheet next to each other and compared them but.........................
Monkradio
Monkradio
