Cobra 25 Nw ltd classic won't turn on?
hi i got a cobra 25 nw ltd from a buddy of mine to work on, he said, "i plugged it one day it turned on and worked fine, and then the next it wouldnt turn on" i tried different power cords and all, i got a suggestion that the diode on the inside of the radio might be bad, the one thats soldered to the power connector, the radio is only from 07' so it should be working great never been tuned or nothing, and is in great shape, any body experience this?
- Real Name: james
Re: Cobra 25 Nw ltd classic won't turn on?
Must be that diode.
yea thats what i was thinkin but i wanted to get some input befor i go forth with it
- Night Crawler
Does it blow the fuse in the power cord when the power supply is turned on?
If it doesn't the diode isn't shorted check it with a VOM before it's replaced.
no i just plug it in, and wont turn om, whats a "vom"? pics?
- Night Crawler
- headhunter1
- Real Name: willy
eather a loose wire on the on and off switch or prob a burnt trace on the back side of the board i have see the diode blow and get the yrace as well
wonder what kind of diode it is, and what kind of ohms i should check for?
Ok it does make my power supply shut off, can sombody please tell me what kind of diode this is in my cobra 25, is it called a polarity diode by chance, please help soon, or im gonna have a unhappy customer,
- Night Crawler
It's a 1N4003 marked on the board as D17 the reverse polarity protection diode.audio boy wrote: can sombody please tell me what kind of diode this is in my cobra 25
http://www.radioshack.com/pro ... Id=2036269
Any general area were its located, thanks alot night crawler for your help.
- Night Crawler
It should be on the circiut board in the back of the radio where the power cord plugs in.
ok i found it it doesnt appear to be burnt up, o and one other thing the negative wire coming from the pwoer plug to the board, pokes threw a hole in the board with solder around it but its not soldered, when i touch it to the solder it shuts off my power supply any idea whats up?
- Night Crawler
That doesn't mean anything the diode still could shorted and it won't show any sign of being bad.audio boy wrote:ok i found it it doesnt appear to be burnt up,
Thats what I'm thinking.headhunter1 wrote: prob a burnt trace on the back side of the board i have see the diode blow and get the yrace as well
After what you described I think it took the trace out that's why it doesn't looked like it's soldered it should be. If the diode is shorted when you touch the negative wire to the solder trace it will shut the power supply down.Check the positive wire also for a loose or unsoldered connection.audio boy wrote: one other thing the negative wire coming from the pwoer plug to the board, pokes threw a hole in the board with solder around it but its not soldered, when i touch it to the solder it shuts off my power supply any idea whats up?
will a burnt trace be very noticeable because everything looks fine to me
- Night Crawler
If a wire is poking through a hole in the circuit board and is not soldered to it that's a problem. If the diode shorted it could of got hot, possibly causing the negative wire to lift from the trace.audio boy wrote: everything looks fine to me
Without looking at the board and testing the circuit it's hard to tell you what the problem could be.
