10/11/12 meter ?
- bigguy
- Super Mud-Duck
- Real Name: brandon
- Antenna: 102 whip
- Radio: Northstar dx 330hml
10/11/12 meter ?
ok so i am new here and i was just wondering whats the difference between 10/11/12 meter radios
Re: 10/11/12 meter ?
10 meter = ham radio
11 meter = cb radio
12 meter = ham radio
You are allowed to use 11 meter radio. A typical 11 meter radio is very low powered and doesn't have many features. Most "10 meter" radios are powerful and feature packed. Most folks that use 10 meter radios buy them and convert them to 11 meter so they get a strong feature packed radio on the 11 meter band.
There's some radios listed as 10 and 12 meter radios like the 2950DX. Typically those cover 10 and 12 but can be converted to cover 10, 11, and 12 meters.
Don't get caught on 10 or 12 meter without the proper license.
11 meter = cb radio
- bigguy
- Super Mud-Duck
- Antenna: 102 whip
i have a northstar dx 330hml this is a 10 meter right
Yes. I'm pretty sure it's a Galaxy 33 HML knockoff. Northstar/Northpoint/Cherokee were knock off radios of Galaxy and Magnum. They're not "bad" radios but may not be the quality of the other big brands. If you're using the radio, and can transmit and receive on 19, then it's already been converted over.bigguy wrote:i have a northstar dx 330hml this is a 10 meter right
If it is converted then just be careful b/c it's not type accepted and not legal to use on 11 meters. Tons of people use them, but I just wanted to get that strait.
- bigguy
- Super Mud-Duck
- Antenna: 102 whip
i see thanx for the info
- longhaireddwb
- Real Name: Jerry
I second the quote:
Don't get caught on 10 or 12 meter without the proper license!
Good luck!
License #: KDOJVP
Good luck!
License #: KDOJVP
10 meters is from 28 to 29.7 mhz
11 meters, "cb" is from 26.965 to 27.405 in 10kc increments with some that skip for other uses, being the "A" channels between 3&4, 7&8, 11&12, etc.
12 meters is down in the top of 24 mhz, 24.93-24.99 I think.
If you choose to freeband it, DEFINITELY stay above 26 mhz and below 28 mhz and even then you're not legal but at least you're not on an active ham band. Still, those "freeband" areas are assigned to someone, some government agency probably, somewhere. Maybe it is the military, maybe the forestry service, but rest assured they are assigned to something and not just free. That said, there is still many who operate there trouble free.
- bigguy
- Super Mud-Duck
- Antenna: 102 whip
thanx again for the info so what is this radio worth if i was to sell it
- outlaw0814
- Real Name: gus
- Radio: Galaxy 959
if u choose to use 10 or 12 meters get a ham licence-- it aint htat hard especially since you dont need code anymore
galaxy 959 mostly stock
575m6 mike
mod V 150
imax w/4ft francis
575m6 mike
mod V 150
imax w/4ft francis
Depending on the antenna you have and they way it is tuned, operation very far outside of the 11m band is probably not going to be practical anyway.
