MODULATORS
MODULATORS
I was just reading about the differance between modulators and amps. Do these things work?
The word "modulator" has many meanings now-a-days. First modulator kits for inside radios are a joke! Often installed by techs that only know how to connect the wires, these generic kits should be avoided. Maybe theres someone out there making a generic kit that works well, but Ive yet to have seen one.
Second type is a modulator, or amplifer. Modulators are small linear amps used to drive bigger amplifers. Example, a texas star mod v, this amp is designed to drive a texas star straight 8 pill box like a 1200 or 1600. Modulators are also sometimes called drivers. Really however most any small amp can be bet up like a modulator.
The reason a modulator makes you "loud" is because when driving a big amp, these small amps key low watts, and swing high watts. If you use a superwackpacked radio, you'll see the same results. Why? Low deadkey, high swing!
