Astro Beam question
Outta_Kontrol
Astro Beam question
Post by Outta_Kontrol »
I was wondering how much power could be run with an old Tandy beam antenna . I would like to pickup a good linear but I don't want to fry the antenna . Any help appreciated .
Outta_Kontrol
And what the heck is with this spell check , can we turn it off so we can post what we want to say ?
PONY EXPRESS
Radio: GOLDEN EAGLE Mark IV
spell check
Post by PONY EXPRESS »
Up on top of page click on PROFILE and you can turn spell check off
Outta_Kontrol
Thanx Pony
Outta_Kontrol
I was wondering how much power could be run with an old Tandy Astro beam antenna . I would like to pickup a good linear but I don't want to fry the antenna . Any help appreciated
linx
Post by linx »
Never heard of a Tandy Astro Beam. Is it the same thing as an Avanti Astro Beam? - http://www.cbtricks.com/ant_m ... _av150.pdf
By the way, welcome to the forum!
231
Post by 231 »
Tandy only made the standard 3 element yagi if I recall. With the simple straight forward gamma match you should be able to run a couple kw's without too much problem (assuming it's in good shape). Should be about the same wattage with the Avanti Astro beam (IIRC).
Welcome to the forum.
998
Post by 998 »
Is that the same as a ASTRO PLANE or STAR DUSTER :?: :?: :?:
J IN THE WOODS OF GEORGIA
73'S CBRT MEMBERS AROUND THE HOUSE HOLD!!!
Outta_Kontrol
The antenna is a Tandy 3 element Astro Beam .Made during the late 70's early 80's to the best of my knowledge
231
Post by 231 »
Outta_Kontrol wrote:The antenna is a Tandy 3 element Astro Beam .Made during the late 70's early 80's to the best of my knowledge
Yea, I think they called that the Archer 3 element. Just a straight forward 3 element yagi. Here is the true Astro-beam.
998
Post by 998 »
Thats almost like the old astro plane except id has a element section and the astro plane went up with a X on the top
Outta_Kontrol
The Tandy Astro Beam looks just like the pic 231 posted but it's not an Avanti t's a Tandy
linx
Post by linx »
Outta_Kontrol wrote:The Tandy Astro Beam looks just like the pic 231 posted but it's not an Avanti t's a Tandy
If it "looks" the same, then perhaps the instruction manual will be the same. Enjoy,
