We Need Your Suggestions on Laptop Stands/Mounts
- Pro-Tech
- Real Name: Red Bud
- Radio: Any radio I want.
Starting August first we are expanding our shop and moving the "Satellite Man" into a bigger space in the same building because of the growth in the VuQube demand and we are needing to make our own brackets now. So now we have a space to fill for laptop merchandise and need to find the best quality laptop stand for our customers. Petro sells the Cyber Trucker for three hundred dollars and we feel that is over priced for the materials involved. Fleabay doesn't offer anything for big trucks so we would like to fill this niche and fatten our wallets even more. If any one knows of a brand that I haven't mentioned please let us know and if you own one you recommend we will appreciate it. Remember quality first and price second. That is how we operate. Who ever gives us the best suggestion we will give you a Pro-Tech "T-Top" golf shirt for helping the effort. Come to think of it we would like to hear of other useful products that enhance the use of a laptop in a "Big Truck".
Thanks members, we back out reading the mail.
- Peanut
- Real Name: Matthew
- Pro-Tech
- Runt
- Real Name: Al
- Radio: RCI690F150
- Bleearg
- Handle: rooster
- Real Name: Rob
- Radio: SWP General Lee
The better ones I have seen were made out of plumbing fittings and pipe and wrapped with split wire loom/ flex tube. The only part that would be hard to find would probably be the piece to hold the top. The tops were thick glass.
Custom made with choice of height, position, color and top size.
That flex tube comes in all sorts of colors.
http://www.electriduct.com/wi ... rpose.html
- radiogeak
- Mud-Duck Sr.
- Peanut
- quickdraw83
I have the ram in my f550 work truck and all the other field techs have them in there trucks as well,i personally have had no problems with mine and as far as i know no other tech has had any problems with theres.One thing i do know is that sometimes the spring under the plate that the laptop sits on makes a noise and if you put some of that wire loom stuff on there it takes care of the noise
- Pro-Tech
- Pro-Tech
