Acquired a vintage Tram D201
ScallyWagger
Super Mud-Duck
Super Mud-Duck
Handle: ScallyWagger
Real Name: Steven Tutty
Antenna: DMXHD-40
Radio: Tram D-201
#388652
Post by ScallyWagger »
Hi all!
I recently came across an old Tram D201. In very good condition but all original components. Slowly learning about all items that I should upgrade/replace (caps/resistors). Curious to learn which items I should tackle first. Any input would be great!
ScallyWagger
Super Mud-Duck
Super Mud-Duck
Antenna: DMXHD-40
Radio: Tram D-201
Re: Acquired a vintage Tram D201
#388658
I picked up the original Tram D201, 23 channel. I assuming it is second production, just prior to move to Mexican production facilities. I noticed that there is a heat signature on cover. Should I start by replacing the main can style capacitors and related resistors. I picked up a JJ 500V dual section tube amp capacitor and mounting clamp to use in place of C5 capacitor. For C624, I was thinking on using axial 10uf 450V capacitors, hiding them underneath.
For resistors, I plan on using metal oxide blue flameproof. For other capacitors, I have a kit for this transceiver. Will this aid in reducing heat? After all, heat = short life.
