colt midnite special
This area is dedicated to talk about tube radios, or amplifiers.
lemmychatter
Radio: uniden 510, tiger 40
Antenna: wilson, firestik
Post by lemmychatter » Sunday, 02 July 2017, 16:03 PM
Does anyone know what microphones will work with a base Colt midnite special? i picked one up at a flea market, real nice shape but no mic. Thanks!!
Re: colt midnite special
Post by jessejamesdallas » Sunday, 02 July 2017, 18:23 PM
Couldn't find anything on the Midnight Special, but if it's a 4 pin, most all of the other Colt radios are wired like this:
Mic Wiring
Stock
1- Audio
2- Shield
3- Receive
4- Transmit
Astatic (4 wire)
1- White
2- Shield
3- Black
4- Red
Astatic (6 wire)
1- White
2- Shield & Blue
3- Black
4- Red
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Red
2- Shield & Black
3- Blue
4- White
Galaxy DC-521S (4 wire)
1- Yellow
2- Shield
3- Black
4- Red
Galaxy CB-660EI
1- White
2- Shield & Black
3- Blue
4- Red
Sadelta
1- White
2- Shield
3- Green
4- Brown
Turner
1- White
2- Shield & Red
3- Black
4- Blue
Yellow NC
If 5 pin:
Mic Wiring
Stock
1- Audio
2- Transmit
3- Shield
4- N/C
5- Receive
Astatic (4 wire)
1- White
2- Red
3- Shield
4- N/C
5- Black
Astatic (6 wire)
1- White
2- Red
3- Shield & Blue
4- N/C
5- Black
Yellow N/C
Daiwa EM-500
Cobra CA Series
1- Red
2- White
3- Shield & Black
4- N/C
5- Blue
1- Yellow
2- Red
3- Shield
4- N/C
5- Black
Galaxy CB-660EI
1- White
2- Red
3- Shield & Black
4- N/C
5- Blue
Sadelta
1- White
2- Brown
3- Shield
4- N/C
5- Green
Turner
1- White
2- Blue
3- Shield & Red
4- N/C
5- Black
Yellow NC
These are different wiring from the standard Cobra/Galaxy radios, so if you buy a New Mic, your going to have to rewire it....
Post by MDYoungblood » Sunday, 02 July 2017, 18:29 PM
Cool looking radio. First I would see if a Cobra 4pin would work, that is the most common wiring or maybe someone rewired the jack to use Cobra, (that is what I normally do). If the Cobra mic transmits when plugged in the TX/RX needs to be switched. there is only 2 different wiring pinouts for a 4pin Colt,
Pin 1 is audio, pin 2 is shield (and switching ground if a 6 wire mic), pin 3 is TX and pin 4 is RX or pin 1 is audio, pin 2 is TX, pin 3 is switching ground, and pin 4 is TX (I would try this one first since it is a tube radio, is definitely relay switching).
If you need more help tell me which mic you are trying to wire up.
lemmychatter
Post by lemmychatter » Monday, 03 July 2017, 12:37 PM
Thanks for all the information. Its a 4 pin ,guess i will have to play around with that. i fired it up today and just threw a mobile mag mount up on my metal shed with a 5 ft firestik to try it. it worked great at first but as it warmed up the recieve signal started to come in and out. i lost static noise all together. somtimes someone would come in strong out of dead silence and then slowly fade away. not sure whats going on there, its my first tube rig. thanks!!
Post by jessejamesdallas » Monday, 03 July 2017, 14:32 PM
Probably weak tubes....
lemmychatter
Post by lemmychatter » Monday, 03 July 2017, 15:41 PM
ya, i think the tubes might be weak or ones bad, heres another weird thing about this rig. i get a little shock when i touch the case. (not opened up, lid screwed shut) its not a big shock but a definite tingle. its too bad its a nice old rig but im not sure its worth having repaired.
Post by jessejamesdallas » Monday, 03 July 2017, 16:11 PM
I have a old tube amp that was doing that...Turned out on the bottom side of the board there was a capacitor that was rubbing the case, and had started leaking...Found out when it started sparking...replaced three cap's that were side-by-side, and put some electrical tape on the case where the original had been rubbing, just to give the new ones a little more insulation from the case...that took care of the shocking.
Just be super-careful messing around inside that radio! Most things inside will literally "Light you up!" :o
lemmychatter
Post by lemmychatter » Monday, 03 July 2017, 17:35 PM
thats what i thought it must be. a leaky cap or somthing. dont worry im not pokin around in this one. i know tube radios can be dangerous. im gonna hang on to it, maybe someday have a pro tech restore it. Thanks!
Post by MDYoungblood » Tuesday, 04 July 2017, 11:19 AM
Your right, those old tubers can make you lay on the floor for a while wondering what you touched. If you can take a pic and post it, there isn't many AM tuber's out there like that, the clarifier control makes this one more interesting.
Scipio Kid
Radio: Cobra 29 LX Tweaked
Antenna: Crummy
Post by Scipio Kid » Wednesday, 05 July 2017, 9:16 AM
Sheesh, when did they make those? I thought by the time 40 channel radios were on the market, nobody was making tube chassis anymore. Or were the top of the line models still using tubes for a while?
Well, that's just one more thing to add to my "didn't know" list. Man, that dang list just gets longer and longer. Then when you add it to the list of things I've forgotten, well I could write a book (except it'd be pretty hard to write about all the things I forgot or don't know ... Now I've got a headache).
Happy Trails
Post by MDYoungblood » Wednesday, 05 July 2017, 11:05 AM
There were several popular models, Robyn, Teaberry, Sonar, and Tram (not sure the 40 channel model passed FCC scrutiny) had a AM radio just to name a few, the Cobra Cam88 didn't get 40 channels either I believe, now I am talking about AM mode only.
