Kris 23+ and VFO problem
This area is dedicated to talk about tube radios, or amplifiers.
B C
Mud-Duck Jr.
Mud-Duck Jr.
Post by B C » Sunday, 17 March 2013, 13:16 PM
I have a Kris 23+ with a Pal VFO. For some reason it does not like to work if the VFO shielded cable is grounded. In other words I only connect the inner conducter of the hook up from the VFO to the radio. Ocasionally my freq. counter goes crazy on both transmit and receive, then if I just touch the base of the D-104 hooked up to the radio it will allow the counter to work as normal. Any ideas, or better yet, ways to fix the problem so the VFO can be hooked up the way it is supposed to be.
Tuesday, 19 March 2013, 17:00 PM
I find it really hard to believe that I am the only guy to have ever encountered this problem!!
C'mon guys put on your thinking caps and help me out with this situation.
Re: Kris 23+ and VFO problem
Post by MDYoungblood » Wednesday, 20 March 2013, 6:47 AM
Hello B C,
Welcome to the forum.I had a couple of the Siltronix models but never a Pal, CB Tricks has a manual for them, it may help.
http://www.cbtricks.com/miscellaneous/v ... /index.htm" onclick="window.open(this.href);return false;
From what I read it may need the special coax.
B C
Mud-Duck Jr.
Mud-Duck Jr.
Post by B C » Wednesday, 20 March 2013, 14:25 PM
Thanks for your help Greg, I do have the proper RG-174 U hook up coax. I am quite sure that the whole problem has to do with the one wire hook up, but if the ground (shield) is connected to any ground the VFO operation stops. Disconnect the ground and it will operate again but with crazy freq. counter readings. The operater that I might be talking to see's or hears no difference on his end.
Wednesday, 20 March 2013, 17:25 PM
I am obviously still looking for the cure for this crazy problem, come on guys scratch your head and help me figure this out and fix the problem.
