Johnson Messenger 223 Capacitors
This area is dedicated to talk about tube radios, or amplifiers.
ScallyWagger
Super Mud-Duck
Super Mud-Duck
Radio: Tram D-201
Antenna: DMXHD-40
Post by ScallyWagger » Saturday, 03 February 2018, 18:26 PM
Hi!
I managed to save a Johnson Messenger 223 today. My neighbor was about to load it onto his utility trailer load of stuff destine for the dump. I checked it out. The unit appears to be working fine. I want to clean it up and replace the capacitors for it is all original. I heard that there are six in particular I should attend to first. Anyone know what their values are? Also, which resistors that are of primary concern for failing. :)
halfwatt959
Radio: too many to list
Antenna: maco base/ whip mobi
Name: karl hammons sr
Re: Johnson Messenger 223 Capacitors
Post by halfwatt959 » Saturday, 10 February 2018, 7:22 AM
All the electrolytic caps should be changed. I'm on my first experience with tubes myself so we can learn together. Any resistors that looked cracked, burnt or falling apart as well.
I HATE COMPUTERS!!!!!
Post by MDYoungblood » Saturday, 10 February 2018, 13:47 PM
Normally not all the caps need replacing, disc caps rarely go bad as with most resistors. First ones to look at and replace are the cardboard electrolytic, they will certainly go bad soon. The resistors to look closely at are the ceramic sand cased ones but look at them all for signs of overheating. Hopefully the values are still written on them if not you will need a schematic and parts list.
ScallyWagger
Super Mud-Duck
Super Mud-Duck
Radio: Tram D-201
Antenna: DMXHD-40
Post by ScallyWagger » Tuesday, 13 February 2018, 22:06 PM
ok, will do
