Cobra 148F GTL
EZ CHOPPER
Cell Phone: 615-967-1568
Cobra 148F GTL
Post by EZ CHOPPER » Monday, 04 December 2017, 9:04 AM
Anyone know how to put variable power in a Cobra 148F GTL Please let me know thanks. I guess picked this up is it a good radio ?
Re: Cobra 148F GTL
Post by sonoma » Monday, 04 December 2017, 12:41 PM
I have one also Chopper. I did the npc mod to mine. it dead keys 2 watts and swing all the way to the max. only way I know how to put variable in the 148 radio is to pull the vr and run wires to the locations the VR was hooked to and put them on an external out the radio variable control like the mic gain and rf gain control. maybe some one else knows another way.
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Friday, 08 December 2017, 8:04 AM
witch VR
Re: Cobra 148F GTL
Post by sonoma » Friday, 08 December 2017, 12:45 PM
vr10 is the control for dead key . this is the one most guys will put an external vr in the radio and run the wires to the spots the vr 10 came out of.
I do not put a variable in a single final radio.for the 148 version radio I put the npc mod in it. you can turn the dead key down to 1 1/2 watts to 2 watts and the mod will give you full swing to the radio on AM. just dropping the dead to 2 watts to run a amp will actually lower the swing also. just depends on what you want to drop the dead key for.
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Saturday, 09 December 2017, 8:13 AM
Ok ill check it out way shouldn't you put variable in a single final radio never hard that
Re: Cobra 148F GTL
Post by sonoma » Saturday, 09 December 2017, 8:41 AM
a single final is rated for a 4 watt dead key and will swing to about 18 at BEST. you can drop the dead key to about 1 1/2 to 2 watts and still swing to 18 . a dual final will swing a lot more. this is just me. never did figure out why some of the radios with a single final the factory put a variable in them other than some people want it. some say they want a low dead key for a amp. if the radio is set up right it will dead key 2 watts for a amp and still swing the full amount.
the only person that will know you have a low dead key is you. the receiving radios will never know you have a low or high dead key.
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Sunday, 10 December 2017, 1:47 AM
Gotcha
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Tuesday, 12 December 2017, 8:44 AM
I took the adjuster out put a 50k pot in it now it will go from 1/2 watt to 5 watts its working great
Re: Cobra 148F GTL
Post by MDYoungblood » Tuesday, 12 December 2017, 11:00 AM
I think a 10K would be better. Did you get a dual pot and replace the RF gain with it?
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Wednesday, 13 December 2017, 0:14 AM
Ok now I have a bigger problem I took this radio and put it in another base unit case everything went well I hade to cut the stem on the ssb pot so I could put the knob back on it cause it was sticking to far out, now my frequency counter is going crazy and the radio is not working. Does anyone now where there is a diagram on this pot so I can bypass the wirings so I can use it on AM till I find a new pot or a wiring diagram on the hole pot. MAN I'm so upset about this I've been working on this thing for 2 days was doing great till I cut that thing.
Re: Cobra 148F GTL
Post by sonoma » Wednesday, 13 December 2017, 2:13 AM
not sure just what you did. tried reading it a few times. not sure what you are calling the SSB pot. any way here is some info for the radio.
http://www.cbtricks.com/radios/cobra/148gtl/index.htm
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Wednesday, 13 December 2017, 9:38 AM
sorry was tired last night its the switch that changes it to am to lsb to usb
Re: Cobra 148F GTL
Post by sonoma » Wednesday, 13 December 2017, 11:37 AM
that makes since now. if you check voltage to the switch the in wire will have about 8 volts going in to the switch. then the switch will put the 8 volts to one wire at a time for am, LSB then USB. just tie the 8 volts to the wire that feeds AM to get it back to working for AM.
should be 4 wires going to the switch. just find the voltage into the switch then see witch wire will turn on the AM mode.
here is all the info from the Cobra web site. maybe this will help you.
http://downloads.cobra.com/CB/Models/148-SERIES/
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Thursday, 14 December 2017, 13:09 PM
going out there here just a few mins ill check that out
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Friday, 15 December 2017, 9:33 AM
finger it out it was the power supply it will read 14.5 and as soon as I turn the radio on goes to 5.6 has to be the power supply I took it out of a cobra 2000. I checked all the grounds cant find nothing so it has to be that.
Re: Cobra 148F GTL
Post by sonoma » Friday, 15 December 2017, 21:44 PM
5.6 volts does not make the radio work as it should. sounds like you may have found your problem
EZ CHOPPER
Re: Cobra 148F GTL
Post by EZ CHOPPER » Sunday, 17 December 2017, 8:52 AM
That wasn't the problem I really find it this time.The variable power I made for it was touching the case was shorting out it working like a champ now I should have looked a little harder.
