Cobra 2000
smoke blower
Cobra 2000
Post by smoke blower » Friday, 01 July 2016, 19:19 PM
What is a good way to put TalkBack in a cobra 2000 gtl I tried jumping the Pa and ex speaker jack but it didn't work for some reason I would like to have nice TalkBack in it
Birthday
Re: Cobra 2000
Post by sonoma » Friday, 01 July 2016, 20:24 PM
I have never tried to put talkback in a cobra 2000 radio. 99.9% of people run a power mic on base radios and talk back does not do well with a amplified mic. like I stated I have never done talk back on this type of radio.
-- July 02 2016 --
after doing a on line search it looks as if you have to short the audio and ground on the front speaker jack from what I found. some have had talk back and found a washer on the speaker plug on the front shorted. that would give them talk back which they wanted to turn off. so looks as if you could do it in reverse from what I read.
smoke blower
Re: Cobra 2000
Post by smoke blower » Saturday, 02 July 2016, 6:17 AM
Ok I will see if that will work I definitely have to put a variable in it though
Birthday
Re: Cobra 2000
Post by sonoma » Saturday, 02 July 2016, 6:49 AM
do a google search and you should get the same info I did last night. they talked about a fiber washer that insulated the phone plug on the front and the washer would be broken or missing from what few I read. if I had a base with echo in it I always have another radio set up to listen to how the radio sounds. when in the house I would just set up a little hand held to set the echo if needed and turn it off when talking so I could turn the mic gain up if using a power mic or stock mic. most of my radios I use a noise canceling mic on them since I turn the modulation up by changing resisters and caps in the mic circuit for audio increase.
smoke blower
Re: Cobra 2000
Post by smoke blower » Sunday, 03 July 2016, 12:13 PM
i just left it alone Sonoma it was impossible to keep it from squealing
Re: Cobra 2000
Post by MDYoungblood » Sunday, 03 July 2016, 13:16 PM
If you want to hear what you sound like on the air build one of these, viewtopic.php?f=6&t=46378&hilit=demodulator" onclick="window.open(this.href);return false; , it only works on AM but that's where the majority talks. It is a nice thing to have if you do a lot of bench work.
smoke blower
Re: Cobra 2000
Post by smoke blower » Sunday, 03 July 2016, 14:05 PM
Could I use a 4001 diode
543FtWorth
Radio: (non-sponsor) 29 LTD
Antenna: *Censored*
Re: Cobra 2000
Post by 543FtWorth » Sunday, 03 July 2016, 15:30 PM
It won't hurt to try but I don't think it will work in such a low current circuit. Just about any small signal diode will work.
smoke blower
Re: Cobra 2000
Post by smoke blower » Sunday, 03 July 2016, 16:35 PM
I don't know if I have anything here that has one in it. I have a hard time reading what number is on them is there an easy way to tell
-- Sunday, 03 July 2016, 18:46 PM --
How about a 4148 diode
543FtWorth
Antenna: *Censored*
Re: Cobra 2000
Post by 543FtWorth » Sunday, 03 July 2016, 18:07 PM
Should work.
smoke blower
Re: Cobra 2000
Post by smoke blower » Sunday, 03 July 2016, 18:09 PM
Ok thanks alot I have all the parts then
ogdoa
Radio: Cobra 2000/RCI2970
Antenna: Maco v5000/102"
Re: Cobra 2000
Post by ogdoa » Saturday, 31 March 2018, 7:31 AM
Wait a minute.....diodes have numbers on em? I know this might sound like a dumb question and this is an old post but I have never seen these numbers. I always depended on the package they were in.
151 FRIED CHICKEN
Branson, MO
Home channel
26.845
