Cobra 148 UTB board and echo
If you need assistance with a radio modification or have any questions, this forum is the perfect place to ask. Feel free to pop in and join the discussion!
MightyMo
Real Name: Morgan
Radio: Cobra 29 and 25
Post by MightyMo »
I'm in the process of installing a Universal Talk Back board (UTB-1) and an echo board at the same time. I followed the instructions and refered to CB Radio Magazine's videos on the topic from youtube, but I have hit a snag. The echo board I'm using I got from 6 star on ebay, but I think it may be a Workman brand echo board. After I got it all hooked up, when I'd key the mic, I'd get a HORIBLE buzzing sound that wouldn't stop when I unkeyed the mic. I'd have to turn off the radio to get it to quit. Upon investigation I realized that the ground wire from the external speaker jack was the issue. The guy in the CB Radio Magazine grounded to a screw that mounts the main circuit board to the case. When I removed this wire and grounded it else where, the buzzing sound disappeared and talk back works.
THE PROBLEM
Now when I key the mic, talk back works, but NO ECHO. Also my receive disappears after releasing they mic and won't return unless I turn the radio off and on again. Any thoughts?
The echo board instructions had me remove the wire from the center terminal from the dynamic pot and solder that wire to the "in" wire and the "out"wire from the board was soldered onto the terminal instead. This makes sense to me, but is different than the CB Radio Magazine video which deals with the mic pins directly. Could this be a problem? Is there a chance I fried my finals or something with the UTB board being grounded improperly?
443 Arizona
Mod Duck
Mod Duck
Handle: Double R
Real Name: Steve
Radio: madison on 5/8 wave
Re: Cobra 148 UTB board and echo
Post by 443 Arizona »
im going to throw out a wild guess and say your audio chip is not the one that allows your mod, to work. has anyone previously modded your radio?
pabxone
Post by pabxone »
Just to be clear , you are installing 2 additional boards - A Talk Back board & an Echo board ?
"Also my receive disappears after releasing the mic and won't return unless I turn the radio off and on again." - That is a relay on one of the circuit boards holding stuck operated - when you power down the radio the relay is released until you key up the microphone again.
Something is wrong with the way you have wired these boards , we really need to know exactly what brand/type the boards are so we can see how they should be wired up.
Something else to consider :- Is your radio a 4 pin or 5 pin microphone socket Cobra 148 ?
The ground return paths on a 5 pin Cobra 148 are different to a 4 pin Cobra 148.
The ground line for the audio is separate from the ground line for the transmit / receive switching on the 5 pins.
Even using a 4 pin microphone with a 4 to 5 pin conversion microphone adaptor could be causing you problems here ?
Handle: sonoma
Real Name: sonoma
Radio: President Washington
Post by sonoma »
pabxone is hitting on the right area. you are doing a 148 with 2 different grounds. I had the same problem and this is what 6 star sent me so I played with the grounds. you can leave either one of the grounds loose and tape one off and it should work. I left the ground off the main board that the wire ran with the 12 volt wire. either one left off should take car of your problem if you have the other wires hooked up right.
The only issue I have ever seen with the T3 is a ground problem once in a while. To solve this if you have a problem just Don't connect the shields of Input Output to ground and that seems to solve it. Thanks for your purchase and if you still want to return it no problem! Have a good weekend!
MightyMo
Real Name: Morgan
Post by MightyMo »
Wish I saw these replies sooner. My fault for not getting on.
Yes, 2 boards. Talkback board is UTB-1 and echo is T3 Echo Board.
My Radio: Cobra 148 gtl, front mic, 4 pin, made in China. Bought from Ham shop. They said I was second owner. As far as I can tell, no other mods done.
After this post, Talkback stopped working. I took the cb to a local CB shop. He told me I blew the audio chip in the talkback board because I grounded it wrong. He couldn't get a new chip so I got a new talkback board and proceeded on my own.
I reinstalled everything. The buzzing was no longer present, but the receive still wouldn't come back. Upon further investigation, I came across a website that indicated the relay on the Talkback board is prone to sticking due to a voltage issue. It suggested placing a 1N4148 diode on the PTT wire from the mic jack, but hooking up the green wire from UTB board before it so only the PTT wire would be affected by the diode. (http://***New Sponsor https://blitzradios.com/ ***.com/rf ... _board.htm) When I did that and tried it, It was better, but still not working right. The echo would only work as long as I kept the mic keyed. As soon as I released, the eco cut short. (I tried adjusting it all different ways). So I took the echo out and just tried the TalkBack board. Still had problems. Any suggestions?
(In the meantime, I've removed both boards and the radio is back to normal.)
I was doing some research on Schottkey diodes for the Cobra 29. I wonder if a Schottky diode in place of the 1N418 would make a difference. I just don't know much about diodes so I wouldn't know what value to get.
Thanks for your responses.
MightyMo
Real Name: Morgan
Post by MightyMo »
Dumb computer.... not sure how it submitted my response twice.
MightyMo wrote: May 18th, 2017, 6:14 pm Dumb computer.... not sure how it submitted my response twice.
No biggie, double posts give me something to do.
