Cobra 29 - L14 L13 L12
- MillSpec
- Real Name: Joe
I know I should remove the barrel from L14
But My radio appears to have hot glue on L13 & L12 to prevent the spread of the coils. Here are some photos.
On My 29 WX, I didn't know you had to heat the wax on L14 and a cracked it. If I can pull the barrel, you think It will matter?
Thanks for the help.
-Joe.
-Joe.
- Rabbit Ears
- Handle: Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
- Antenna: Hygain Penetrator 500
- Radio: RCI 2995DX CF
Re: Cobra 29 - L14 L13 L12
What parts do you need??
I've got a few coils to spare.
USA FOREVER
RCI 2995DX CF (PRIMARY BASE)
President HR2600 with Palomar TX-150 amp(backup base) *solar powered*
Turner Super Side Kick
RM Italy KL300P (A/B modded) in truck
BIRD 43P
HY-GAIN SPT-500 antenna
BIRD 43P
And another Golden Screwdriver is born. The Wax is there for a reason! Why are you messing with the Bias?? Leave it alone there is no gain to be made increasing power from 4- 10watts, not even 1 S unit on the receiving stations meter. Not to mention the bleed over you'll produce. Adj vr4 For 100% modulation and call it a day.
Personally I just chalk it up as a learning experience, you have to remove the wax before trying to make adjustments. Yes it needs to be replaced that is why us old guys keep junkers around, parts. If this is the 29LTD-WX you only adjust L14, tweaking the coils will only give you a false watt reading.
- MillSpec
- Real Name: Joe
Rabbit Ears wrote:What parts do you need??
It looks like I need to replace L14.
-- Sunday, 05 October 2014, 8:24 AM --
I had read around. I was under the impression that Removing the plug from L14 and Spreading the Coils on L13 and L12. Along with 100% on VR4 was a part of the swing kit mod.MDYoungblood wrote:Personally I just chalk it up as a learning experience, you have to remove the wax before trying to make adjustments. Yes it needs to be replaced that is why us old guys keep junkers around, parts. If this is the 29LTD-WX you only adjust L14, tweaking the coils will only give you a false watt reading.
I'll replace L14 and NOT spread the coils.
Thanks
-Joe
-- Sunday, 05 October 2014, 8:26 AM --
-357Mag wrote:And another Golden Screwdriver is born. The Wax is there for a reason! Why are you messing with the Bias?? Leave it alone there is no gain to be made increasing power from 4- 10watts, not even 1 S unit on the receiving stations meter. Not to mention the bleed over you'll produce. Adj vr4 For 100% modulation and call it a day.
Isn't that what your first project radio is for? Earning your golden screwdriver trophy?
Okay, installing a swing kit it's best to follow the instructions, so go ahead, spread them just be careful and have a pair of needle nose handy to squeeze them back.MillSpec wrote:I was under the impression that Removing the plug from L14 and Spreading the Coils on L13 and L12. Along with 100% on VR4 was a part of the swing kit mod.
PS, we were all "Golden Screwdrivers" once.
The slug in the 2nd pic from the top is the TVI trap. Looks like someone already monkeyed with it so just leave that one alone. You will gain nothing from spreading the coils with the wax on them. Someone broke L14 but it will still function.There are ways to get L14 to peak out without just removing the slug but the info is out there and just has to be sifted through. The biggest secret to making a cobra 29 walk the dog and kick the cat is keep it pretty close to stock and put an amp behind it. A basic tune up and a variable if you're going to run an amp is all they need. The RX can be pretty noisy out of the box so a good alignment often makes a world of difference. I do like the mod that makes it come up to freq slowly when you key (the MMM whistle sounding thingy) sounds cool when you key on someone.
Bias???-357Mag wrote:And another Golden Screwdriver is born. The Wax is there for a reason! Why are you messing with the Bias?? Leave it alone there is no gain to be made increasing power from 4- 10watts, not even 1 S unit on the receiving stations meter. Not to mention the bleed over you'll produce. Adj vr4 For 100% modulation and call it a day.
- Handle: Mr 231
- Real Name: Mr. 231 in the Carolinas
- Antenna: Sirio 5000
- Radio: President McKinley
Looks like someone also moved the diode over?
Are those copper coils the 54 mhz traps?
