technical difficulties
dad333
Mud-Duck Jr.
Mud-Duck Jr.
Cell Phone: 5409586677
Post by dad333 » Friday, 07 April 2017, 16:13 PM
I need some help please
I have a 2012 freightliner Cascadia and when I hook up my 250w linear with my radio and key up it shuts down my dashboard everything goes off
please tell me what is wrong
thanks
Re: technical difficulties
Post by MDYoungblood » Friday, 07 April 2017, 16:41 PM
It could be a number of things. The first thing that probably isn't done is bonding he vehicle. I know the majority of the body panels are plastic, so add a ground wire from the case of the radio and the amp to a good ground surface. SWR has to be right too, anything over 1.5:1 is going to cause problems like you are experiencing. Now what brand amp is it, that we need to know to say how dirty a signal it puts out. This is a start, will probably see more info as others chip in.
dad333
Mud-Duck Jr.
Mud-Duck Jr.
Post by dad333 » Friday, 07 April 2017, 17:46 PM
RM MOD.351/P AMPLIFIER 60-200W (KL400)
can I use the wires in cb spot or would you recommend using all new ones for the radio and the amp
Post by MDYoungblood » Friday, 07 April 2017, 18:08 PM
Okay, I am not talking about the negative leads on the radio and amp, what I am saying is to add a wire from a case screw to ground, not to the 12v power terminals for accessories in the cab. There should be a ground terminal under the dash but don't run it to where the dash electronics is hooked up, that might cause a ground loop. The amp is actually very nice, I run the same thing in my pickup. Once you have added the grounds start off on #1 position and try each until the amp interferes with the dash components then go back a number and I wouldn't go any higher, I use #3 position and no one can tell the difference between 3 and 5.
dad333
Mud-Duck Jr.
Mud-Duck Jr.
Post by dad333 » Friday, 07 April 2017, 20:37 PM
Thank you sir I will try this and get back to you
