What size power supply?
funonahonda
Post by funonahonda » Sunday, 25 August 2013, 17:31 PM
I have a General Lee that I wanna use as a base set up, what is the smallest size power supply I can use? Thanks
Re: What size power supply?
Post by MDYoungblood » Sunday, 25 August 2013, 20:20 PM
Hello funonahonda,
Welcome to the forum. The easiest way to see what power supply you need is to just pop the fuse and see what size it is, saves a lot of guessing on our part. I am guessing a 20 amp PS will do fine, you might want a little bigger if you plan to upgrade in the future. When looking into then check the continuous amperage, most of the model numbers are the surge amperage.
dirtyjob
Radio: Many
Antenna: Super Penetrator 500
Home Phone: Unit 613 Boston
Cell Phone: CBRT 18204
Referrals: 2
Post by dirtyjob » Sunday, 25 August 2013, 22:01 PM
a 10 amp will run the lee
"LISTEN FOR THE PING"
Kenwood TS-590S - Yaesu FT897D - W2IHY 8 Band EQ - W2IHY EQPlus
Gizmotchy G-31 Beam
Super Penetrator 500 5/8 Wave
Comet GP9 2 meter/440
CBRT 18204
(Click image to enlarge)
hank_612
Radio: Grant XL + M4V
Antenna: Gainmaster
Home Phone: 6368675309
Cell Phone: 3148675309
Post by hank_612 » Sunday, 01 September 2013, 13:37 PM
Get 20 or 25 amp. If you get the lee swinging hard it will draw close 10 amps. I always figure a power supp needs to be rated at least 20% more than what is called for.
