Connex 3300hp modulation
Name: RON D HOLLAND
Cell Phone: 5402951253
Post by 567 » Saturday, 28 October 2017, 12:03 PM
I recently purchased a used Connex 3300 HP. When I key down the transmitted light turns red in the TalkBack works. No movement on the meter built into the radio. I added a SWR/POWER METER on line and still nothing.
Any help will be greatly appreciated.
PS I am also running an after market noise canceling mic.
Thanks 567/Double J
Logged in via: iPhone
Re: Connex 3300hp modulation
Post by MDYoungblood » Monday, 30 October 2017, 12:18 PM
Hello 567,
Welcome to the forum. Sorry it took me so long to attempt to help. Sounds like the final in gone, probably the driver too. Radios these days don't handle a high SWR as well as older ones and with shops doing "peak and tunes", they stress the radios circuitry. I doubt if the mic has anything to do with the problem.
I see your a new member, could you post an intro in the "Welcome to the Forum" topic, viewforum.php?f=89 , so others here can say "Hi", thanks.
Post by sonoma » Monday, 30 October 2017, 13:04 PM
just saw this one myself, do as MDY said . are the finals mosfets or bypolars? check voltage on each leg in TX and RX modes. also check the large component mounted to the side of the case. it will be a 2sb817 or 754 depending on how old it is. check it in TX and RX modes also. it has 3 legs on it as the final but larger. post your findings.
Post by MDYoungblood » Monday, 30 October 2017, 14:02 PM
That is a good question sonoma, most I have seen had dual fet's in it, (EPT360014B), maybe 567 can give us a little more info. The extremely new radio is SMT.
With the TB working and the TX light shows function the first thing and I'm guessing like always is the driver has gone bad, possibly both finals too. Could be something simple as one of the diodes or the board got hot and lifted a trace.
It is a popular radio here, truckers like them, easy to tune, but in the wrong hands and the short antennas truckers like to use they are easy to let the smoke out too.
Post by sonoma » Monday, 30 October 2017, 14:31 PM
he did not give much info on the radio so thought I would ask the question.
since I do not work on them much any more did not know the radio is now using smt parts. that sucks
