Tight receive on my Uniden Washington
- Badge19
- Handle: Gearkeeper
- Real Name: Dave
- Radio: Galaxy 2517/Cobra 2000/Galaxy 2547
The receive on my Washington seems to be unusually tight. Having trouble pulling in distant stations. I hooked up a different radio on the same base antenna(A99) and got twice the receive signal; same operator in same location for both transmissions. Is there an adjustment/repair that can be done to improve the receive..??
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
Re: Tight receive on my Uniden Washington
more than likely just needs the receive tuned. some one more than likely got inside with a screw driver and turned L cans that did not need to be turned trying to increase the TX
If no mods were done to the radio a quick blast of deoxit to the controls might wake up the receive especially the RF Gain control. If that doesn't help or like sonoma said, someone was inside the 2 main load cans to adjust (plastic tool only) are L3 and L4 (PC-385 board), adjust these to maximum sound on ch 19 AM. If after this it is still the same then it needs to go to a shop were they have the equipment to make a complete alignment.
- jon6667
- Real Name: jon
- Antenna: dipole
- Radio: icom 7300
sounds like you need a full alignment. like the others told you
- narfedwards1
- Handle: the fonz
- Real Name: Narf
- Call Sign: 421
- Antenna: Gainmaster homebrew@25'
- Radio: CPI CP2000
If its the 858 chassis,change the tap on L4 to the high impedance unused leg and retune L4 and L5 .you will be amazed.Theres a youtube. Video by a swiss guy that goes over the mod.Highly recommended on 858 boards.
[ Post made via Mobile Device ]
Narf!
XM42-9578
North Shore Lake Ontario
"The Shwaaaa" Unit 421
XM42-9578
- Rabbit Ears
- Handle: Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
- Antenna: Hygain Penetrator 500
- Radio: RCI 2995DX CF
jon6667 said it.... (I'm an retired technician). It takes proper equipment and a fine tech to make it sing.
Yesterday I just aligned a Realistic TRC-490 (same board as the latter Washington radios *8719 chip*). The receive sucked...NOW AWESOME...TX was badly hacked and now AMC/ALC is back. TX is crystal clear and dead on frequency.
Hooked up to a Palomar TX-150 ...OWWZA!! Superb!
USA FOREVER
RCI 2995DX CF (PRIMARY BASE)
President HR2600 with Palomar TX-150 amp(backup base) *solar powered*
Turner Super Side Kick
RM Italy KL300P (A/B modded) in truck
BIRD 43P
HY-GAIN SPT-500 antenna
BIRD 43P
