galaxy 33 dead
- bluecurt49
galaxy 33 dead
the radio does not have any tx or rx, tr 30 has no voltage ive changed tr 36-37 38 still no luck. changed d77 . does any body have an idea
- 295 antenna
- Moderator
- Handle: 2950 or 295
- Real Name: Charles Reney
- Antenna: patriot, Discone
Re: galaxy 33 dead
internal fuse ?
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
Re: galaxy 33 dead
just like most of the guys are finding bad solder joints and wire problems even dirty switches on the old radios. check all around the PLL,vco, and audio ic areas. do you even have voltage to the PLL? has some one tried to peak the radio and turned the wrong can and killed the vco area.
- bluecurt49
Re: galaxy 33 dead
I do have voltage at the pll and I have checked all around the audio- vco -pll areas no bad solder joints.replaced audio chip and d78 still no change
- sonoma
- Handle: sonoma
- Real Name: sonoma
Re: galaxy 33 dead
have you made sure the PLL is locked as I mentioned and 10.240 at the PLL and crystal.verify the vco is locked if you are sure there is no bad solder joints. did you check them in those areas with a good magnifying glass so they come in good. I even use a microscope to get a goos look at the joints to see for bad solder. some I will hit them if they look slightly bad. can not even start to say how many over the years came back after touching up solder. also make sure the controls on the front of the radio are clean. they can kill a radio at times when they are dirty. just got a galaxy 44 going off ebay for bad controls . after cleaning the controls the 44 came back to life. a tech had checked it from what the ebay seller said when he sold it. bought it for 25.00 shipped due to a tech telling him it was not repairable.
- bluecurt49
Re: galaxy 33 dead
Thais I'll try again
- sonoma
- Handle: sonoma
- Real Name: sonoma
Re: galaxy 33 dead
there is more to this than just saying you have voltages to it. you need correct voltages. here is a link to a galaxy 33 that has the service manual and it has two or three pages with voltages that are about normal for each part inside the radio. you can have voltages every where but if they are not correct you are just wasting you time checking and not getting the proper voltages to each leg of a part.
http://www.cbtricks.com/radio ... /index.htm
