RF gain problem
bluecurt49
Radio: galaxy dx 95t2
Antenna: wilson 5000
RF gain problem
Post by bluecurt49 » Wednesday, 25 January 2017, 18:26 PM
I have a connex 3300hp and the rf gain knob don't change the noise none ive changed the pot and transistor checked the resistors and it hasnt helped any ideas
Re: RF gain problem
Post by jessejamesdallas » Wednesday, 25 January 2017, 20:53 PM
Is this a New radio? Someone could have added a Variable Power in place of the RF Gain and just set the RF Gain to wide open...Check your DK and see if it changes when you adjust the knob.
Logged in via: iPhone
Re: RF gain problem
Post by MDYoungblood » Thursday, 26 January 2017, 10:51 AM
The RF gain doesn't reduce any noise just the receive signal, does the signal meter drop when you turn the knob to the left?
bluecurt49
Re: RF gain problem
Post by bluecurt49 » Thursday, 26 January 2017, 17:02 PM
it does not change anything and it is an connex3300 side mic. its an old radio
bluecurt49
Re: RF gain problem
Post by bluecurt49 » Thursday, 26 January 2017, 17:36 PM
what would cause it to quit working
Re: RF gain problem
Post by sonoma » Friday, 27 January 2017, 7:32 AM
trace the wires where they solder to the main board and verify they are making good connection. you could have a bad solder joint in the area where the wires hookup causing it not to change. get your magnifying glasses on with a solder gun and start checking for a bad solder joint. even look at the caps in that area since you said it is a old radio. you may have some of them failing. look on cbtricks.com under connex and they have a picture of the main board for active devise locations. this will also help you look at each part location. I bought a galaxy 44hml whish is a old radio on ebay for next to nothing because it did not work properly and it had bad solder joints in the vco PLL areas. works great now.
bluecurt49
Re: RF gain problem
Post by bluecurt49 » Monday, 20 February 2017, 19:00 PM
the problem was fixed the ground wire on the switch was in the wrong place on the switch
Re: RF gain problem
Post by sonoma » Monday, 20 February 2017, 19:13 PM
glad you found it. just takes time to trace out the wires and the locations plus bad solder joints on most radios.
