Antenna switches used in reverse
- Real Name: Hal
- Antenna: Comtelco mag mount
- Radio: Cobra 19 ULTRA III
I need a switch that feeds 4 CB radios into one antenna at a time for reception comparison, I was looking at the Alpha Delta ASC-4B switch which feeds one radio into 4 antennas, could this application be reversed without any negative effects? Would I really would like is a dual type switch that has maybe multiple inputs & at least two outputs so I can also choose a Omni or a beam between each radio depending on the switch configurations. Thanks in advance & have a safe & happy weekend all.
Re: Antenna switches used in reverse
Yes it will work but be warned you wouldn't want to key up a radio that is in the grounded position of the switch. To remove that possibility from happening, take the back plate off the switch and remove the grounding lug. You might want to check out the MFJ-1700C switch.
- Bluerunner
- Handle: BlueRunner
- Real Name: Mike
- Antenna: Starduster
- Radio: Cobra 142
Any switch should do. Some are the "shorting" type. They ground the antenna / radio to ground when that position is not selected.
I sometimes run multiple radios on a 4 way non-grounding switch, and 4 antennas on another 4 way switch. Been wanting to try a grounding switch. Might give more isolation.
The antenna switches are after the amp output. I suspect there is insufficient isolation in an antenna switch to run a big amp on one input and a radio on another. Might smoke the radio.
Why do that? I don't know, but I must have wanted to at one time, and realized it was a bad idea or I wouldn't have thought to mention it.
Every device you put in line has it's own input impedance and may change your SWR reading, depending where your SWR/Power meter is in the chain.
Give this set-up some thought if you are handy with some simple DIY work
http://www.dooleystreasureche ... /patch.htm
[quote="pabxone"]Give this set-up some thought if you are handy with some simple DIY work
http://www.dooleystreasureche ... /patch.htm[/quote
Interesting, kind of like an old telephone operators switch board.
I'd rather have the unused radios grounded. Seems like less RF would be coupled into the unused rigs. How about some beefy 50 ohm resistors in place of the grounding bar? Each unused rig would essentially be connected to a dummy load. If you key too long and burn the resistor you're back to the open circuit.MDYoungblood wrote:Yes it will work but be warned you wouldn't want to key up a radio that is in the grounded position of the switch. To remove that possibility from happening, take the back plate off the switch and remove the grounding lug. You might want to check out the MFJ-1700C switch.
- 295 antenna
- Moderator
- Handle: 2950 or 295
- Real Name: Charles Reney
- Antenna: patriot, Discone
If i understand the question right . I use a antenna switch for three radios to one antenna and have for a long time all with power .
- Real Name: Hal
All very good suggestions gents, I don't have my tools anymore to DIY at the moment but in time I will start getting into that with antennas, since my HOA allows only one antenna that cannot extend past 10' above my house roofline & no beams at all so I am going to get one of the Big Stick style fiberglass verticals like the IMAX, A99 or equivalent & mount it on a pipe in the ground while pondering DIY'ing the venerable AS Super Scanner CB antenna if I can find some decent easy to understand plans. In the meantime I'm still looking at my radios sitting in their boxes until I can get things going at my new place, I'm live streaming channel 6 on Broadcastify & monitoring local CB on a basic RTL-SDR dongle which is really cool with that waterfall display but I need to learn more about stand alone SWR meters so I don't blow my radios up, lot's to learn but you guys are very considerate, patient & above all knowledgeable & for that I am very grateful, today was a very memorable one so everybody have a good weekend.
