Swapping Crystals
Slim Pickins
Radio: Realistic Navajo 457
Swapping Crystals
Post by Slim Pickins » Monday, 12 April 2010, 17:43 PM
Can I change out a crystal from a channel I don't use to get a channel I do in an old 23ch radio. Mostly all the locals run ch24 around here and I would sacrifice a channel I don't use to get 24 if that were possible in my Spitfire Mark II tube radio.
73s
Paul
73,Slim
heavyD
Radio: galaxy,cobra,uniden
Antenna: imax, steel whip
Re: Swapping Crystals
Post by heavyD » Monday, 12 April 2010, 18:31 PM
good luck... bump, i would like to know too :)
Heavy-D. 529 in the Pile
Slim Pickins
Post by Slim Pickins » Tuesday, 13 April 2010, 15:34 PM
Good to know I am not alone.
Paul
73,Slim
Night Crawler
Post by Night Crawler » Tuesday, 13 April 2010, 15:52 PM
Slim Pickins wrote:Can I change out a crystal from a channel I don't use to get a channel I do in an old 23ch radio.
Sure it can be done the frequency of the crystal or crystals would have to be determined by what mixing scheme that radio is using.
If it's one of the easier mixing circuits only two crystals would have to be changed to give the radio a new bank of 23 channels above or below channel 1 or 23.
That radio should have the same circuit as the Robyn T123 or T123B with a bank of 37mhz and 4mhz crystals with one 6.000mhz and one 5.545mhz for the 123.
If it's the same as the 123B it will have a bank of 23mhz and 14mhz crystals and one 11.275mhz and one 11.730mhz crystal open up the radio check and see.
If it's not using those crystals give me the frequencies of all the crystals that are in the radio and I'll tell you what has to be done.
Slim Pickins
Post by Slim Pickins » Tuesday, 13 April 2010, 18:23 PM
Thanks Night Crawler,
I will open up the radio tomorrow night and let you know what crystals are in there.
73s
Paul
73,Slim
Slim Pickins
Post by Slim Pickins » Wednesday, 14 April 2010, 13:13 PM
Ok, Here's what I found,
10 crystals Left to right when looking at the radio from the front on a rail behind the channel selector
23.440
14.950
14.950
14.970
23.390
23.490
23.340
14.990
23.290
23.540
I hope I didn't miss any.
Paul
73,Slim
Night Crawler
Post by Night Crawler » Wednesday, 14 April 2010, 13:22 PM
That's one of the simpler mixing circuits.
I'll get the information together and explain what has to be done I'll send you a PM this evening or tomorrow.
Slim Pickins
Post by Slim Pickins » Wednesday, 14 April 2010, 14:41 PM
I missed a couple,
on the bottom of the radio attached to the fine tune knob is 11.730, and on the bottom of one of the tubes is another 11.275
thanks
Paul
73,Slim
