Base Antennas Set-up
- RIVER RAT 52
- Super Mud-Duck
- Real Name: Paul Wymer
- Antenna: Imax 2000
- Radio: Cobra 2000 GTL
I could use some advice about my planned antenna set-up. This spring I want to install a antenna, looking at the Imax 2000, and I would like to know what advantage I get from a ground plane kit, or should I sink a 2" x 10 ft. pole in the ground and work from there. Also, I have a Uniden BCD996P2 scanner, can I attach it's antenna to the same pole as the Imax 2000. Would like to go with the Scanner Master Diamond Super Discone. Any help would be greatly appreciated.
- Tweetybird
- Handle: Tweetybird
- Real Name: Gary
- Antenna: Max 2000
- Radio: 2517 /2995
Re: Base Antennas Set-up
I run the IMAX for about 7 months before installing the GPK. It was like putting up a different antenna, the noise is gone and got rid the TVI. I too have Scanner antenna's but have them on a different tower, I wouldn't install a scanner below the IMAX if was me. The GPK did raise the SWR not worth adjusting, 1.2 versus 1.1 SWR. You will pros and cons with the GPK but it worked for me.
Some people notice an improvement with the GPK and some don't. My opinion is that if you're going to spend the money on an imax plus a GPK you should buy an aluminum ground plane like the maco v58, maco v5000, penetrator 500 or similar. For the same if not less money you get a better antenna.
- KP68
- Handle: KP68
- Real Name: Ken
- Antenna: Maco M105C Mr Coily 80meter sky loop
- Radio: Apache Labs ANAN 7000DLE MKii
I don't know what your situation is with space requirements/restrictions, but if there is no issue, I would undoubtedly go with an aluminum ground plane. Whatever antenna you do go with, if you have the choice of power handling capability of two models, for instance like the V5/8 or V5000, I would spend a little bit more for the antenna with the higher wattage rating. If one thing holds true for most CBer's is that whatever power you are running now, it isn't enough. This leaves room for future station upgrades.
Also might look at the sirio vector 4000 or even the sirio 827. I am currently using the vector 4K and it rocks! Have had some bad weather and very high winds of 25+mph sustained for over 3 days straight and antenna is still as it was when first put up. Just want to mention this as some think this is a flimsy antenna, and it will blow around no doubt, but no more than most other antennas that are of the same height or near the same height. Aluminum all the way. Keep the fiberglass for fishing poles and boats!! JMHO.
I agree with everyone about a metal antenna. I did install a Imax 2000, (new ones are just Max 2000), had it on a 20ft push up mast, also tried the GPK and saw no improvement. It came down and I install my 40yo Avanti Sigma II, world of difference, it's a metal antenna for me.
- RIVER RAT 52
- Super Mud-Duck
Thanks for the info. I think I'll start looking for an aluminum antenna. No issues here with space/requirements/restrictions .I will be mounting it near the house and can secure it to the eave. Will that be a problem?
Fastening to the eve isn't a problem as long as at least one of the lag bolts hit a stud, best if all fasteners get into studs. Add another mount about half way down the mast if possible. A mast going from antenna to the ground is best but if it's roof mounted then a hefty ground wire down to a good earth ground is needed. You'll find plenty of info about this in the topics.
- WDVLRDIO
- Mud-Duck Sr.
- Handle: Lurker
- Real Name: Daniel
- Radio: General Lee
Thanks for the preferences and info. I too am in the market for a base antenna and I was looking into the imax 2000.
From all of the reviews that I've read about Mr. Coily's Excalibur .64 base it sounds like a great antenna...if you're willing to pay $550. This is my next antenna!
It is a heavy duty well built antenna. Don't expect it to perform much differently than any other 5/8 wave antenna. They say 8db gain compared to other types and ratings but what does that even mean? Maybe an a99, imax, firestick....who knows.
The .64 wavelength thing makes it about 6 inches longer. You've got enough material to stretch any 5/8 antenna to .64 if that's what you want. A 5/8 antenna is a 5/8 antenna. If you want to make it as efficient as possible you use a low loss matching device. Think about using a 102 whip on the mobile vs a coiled antenna.
Edit:
You can stretch any 5/8 antenna to .64 if the matching device is adjustable. Something like a p500 you would not be able to without other modifications.
Edit:
$550 is a lot of money to spend on a vertical antenna. .64w or not. Is the gain really that much better vs. a 5/8th wave antenna. Just scratching my head over how much the price difference is between antennas here is all. I mean the shockwave isn't cheap, but $550 is a lot of loot for a vertical antenna!! Maybe they are worth every penny, but I would research the benefits vs the cost before I pulled the trigger on something like this. JMHO.
