Maco 4 Element Beam opinions
Tinman590
Radio: Icom and RCI-2980
Post by Tinman590 » Wednesday, 17 November 2010, 17:35 PM
I just ordered a new beam m104 I plan on mounting atop my 50' tower with my imax above it. Just wanted to get opinions, I wanted more elements but a tree that cant be cut is in the way.
RCI-2980WX
Henry Radio 2k2
Imax 2000
4 element maco
RCI-2950 twin tube modulator
Cobra 2000
Washington
A bunch of other stuff
bigbronco44
Mud-Duck Sr.
Mud-Duck Sr.
Home Phone: 5145711969
Re: Maco 4 Element Beam opinions
Post by bigbronco44 » Wednesday, 17 November 2010, 18:25 PM
You will luv that antenna I run a maco 103 on a 60ft tower best bang for your buck and the 104 is even better
Tinman590
Post by Tinman590 » Thursday, 18 November 2010, 5:20 AM
bigbronco44 wrote:You will luv that antenna I run a maco 103 on a 60ft tower best bang for your buck and the 104 is even better
Im looking foward to it!
RCI-2980WX
Henry Radio 2k2
Imax 2000
4 element maco
Cobra 2000
Washington
Post by drdx » Thursday, 18 November 2010, 6:09 AM
Enjoy it. Are you putting a vertical on top of it? If you do the beam will make a good ground plane for it. Buy a remote coax switch so you only have to buy one run of coax, and get good coax.
721HACKSAW
Post by 721HACKSAW » Thursday, 18 November 2010, 6:46 AM
If you are mounting the beam horz. with the Imax on the same mast above it. Mine works great, check out my signiture pic. The more elements the better. I did replace the Maco hardware with stainless though.
Good luck and be safe.
tim2
Post by tim2 » Thursday, 18 November 2010, 7:39 AM
i like mine started with 3 got the kit made 4, down side doesn,t have bigger boom od like yours will.didn,t know about remote coax switch i have 2 fed lines ..up about 46 ft to boom vertical with mad max on top both work very well .. gamma match was a lot tricky for me , finaly put up a coaxial choke standingwave is real flatt . but thats a whole another deal if choke helps swr or not meter says yes but ' Doc says no .. he can tell you more on that .check .. check and double check .. have fun !!!!!!!!
JUST MY 2 CENTS .... MEANS NOTHING !!!!!!!
Tinman590
Post by Tinman590 » Thursday, 18 November 2010, 9:52 AM
drdx wrote:Enjoy it. Are you putting a vertical on top of it? If you do the beam will make a good ground plane for it. Buy a remote coax switch so you only have to buy one run of coax, and get good coax.
Good tip but I already have 213 ran to a 2m beam that I am replacing with the flat for 11m so I will use that. And yes I am putting my vertical atop the flat beam. Im like a kid waiting on santa.
RCI-2980WX
Henry Radio 2k2
Imax 2000
4 element maco
Cobra 2000
Washington
Nagant
Radio: To Many To List
Antenna: M104C, V-Quad
Post by Nagant » Thursday, 18 November 2010, 16:15 PM
I'm sure it will work very well for you. If you can and have the time after you're finished takes some pics for us.
Worm on AM or 262 on SSB.
Pills are for swallowing!
Users browsing this forum: Russ and 1 guest
