Tuning an Antron 99
Dreven
Radio: Connex3300 Galaxy949
Home Phone: 2566012163
Tuning an Antron 99
Post by Dreven » Sunday, 02 May 2010, 18:25 PM
Is anyone familiar with how to tune the Antron 99 .
Double D
Radio: 2 Cans and a String
Antenna: Isotropic Radiator
Home Phone: (412)555-1212
Cell Phone: 1-800-MUD-DUCK
Re: Tuning an Antron 99
Post by Double D » Sunday, 02 May 2010, 19:31 PM
You really shouldn't have to tune it but if you find that you need to just pick a channel and turn the rings together until you get the lowest SWR.
"To acquire knowledge, one must study;
but to acquire wisdom, one must observe."
Dreven
Post by Dreven » Sunday, 02 May 2010, 20:30 PM
Ok any idea which way the rings need to go to shorten the antenna , my swr is higher on 40 thann on 1
Double D
Post by Double D » Sunday, 02 May 2010, 20:35 PM
Try them at the top first and if that isn't suitable then move them to the bottom.
Dreven
Post by Dreven » Monday, 03 May 2010, 9:18 AM
1.7 on channel 1 , 1.9 on channel 20 , 2.0 on channel 40 . Thats with the rings all the way up , all the way down had the swr on 40 at 3.0 . May wind up having to cut some off the steel whip thats on top.
Double D
Post by Double D » Monday, 03 May 2010, 12:02 PM
With the results that you have I think you need to try a different location for that 99. :icon_e_surprised:
RCII
Post by RCII » Tuesday, 04 May 2010, 7:45 AM
I just bought one and spent yesterday afternoon adjusting the tuning. Mounted in a temporary location with the base 15' off the ground fed with 20' RG-58, I moved the rings around quite a bit and settled with them set between 6 and 7 threads showing from the top. I was not able to get the VSWR down as low as I'd have liked, but it may be a bit different in it's permanent position anyway. This seems to be a good compromise setting though I''ll have to trim it some to get it where I'd like on 10 meters. Looking at my notes, here what I have with it set here:
VSWR 1- 1.3
40- 1.6
50 Ohms at 26.664
2:1 VSWR bandwidth: 21.152 - 27.694.
Adjusting them all the way to the top was considerably worse (1.7-1.8 across all 40 channels), and going lower than 7 turns showing was about the same on 27 MHz.
15-10 meters would be nice to have, but this antenna (at least at the test location) just isn't going to do that. I figure 15/12/11 isn't bad so I'll leave it at this for now.
Rick
RCII
Post by RCII » Saturday, 08 May 2010, 16:26 PM
Well it turns out the tuning was quite a bit different when it was raised to 35' and fed with 100' of RG213. The resonant point was nearly 1 MHz lower. I just cranked the rings up 3 turns and raised it back up and the VSWR is below 1.4:1 across the entire CB band. The 2:1 point us now around 21.385, so I've lost part of 15 without a tuner, but I now have below 2:1 up to 28.185, so there is that.
So it looks to me as though the ring adjustment made a more noticeable difference at the greater height, as well as the resonant frequency being lower than at 15 feet.
Interesting.
Rick
North Texas Mudduck
Post by North Texas Mudduck » Saturday, 08 May 2010, 19:32 PM
Dreven wrote:1.7 on channel 1 , 1.9 on channel 20 , 2.0 on channel 40 . Thats with the rings all the way up , all the way down had the swr on 40 at 3.0 . May wind up having to cut some off the steel whip thats on top.
and why is there a steel whip on top
im now guessing someone just screwed it on top without cutting it down to tune in?
Users browsing this forum: Google [Bot] and 5 guests
