Thanks for the link.doctor wrote:LOOKS great to me.
Did you know you can build a home made beam also, measurements are easy with antenna calculator, and you can mount it on a cut piece of 2x4 or similiar mounting, run your coax to the center, wind around 5 turns of coax for your match....
I built one for 15 meters and worked the pacific.
Go to homemade 10 meter yagis for easy plans just use the antenna calculator for the measurements...
DOCTOR/CBRT 908
ANTENNA CALCULATOR
http://bfn.org/~bn589/antenna.html
I've started one already. Look here:
http://www.cbradiotalk.com/vi ... =5&t=26888
