Moxon beam
Mtn Lynx
Radio: Anytone AT 6666
Antenna: A99/Wire dipole
Moxon beam
Post by Mtn Lynx » Thursday, 12 January 2017, 22:37 PM
I've been reading about Moxon Antennas and saw that HomerBB made one with a walker. Saw that mfj makes one, and it performed really well on a YouTube video where one dude from Ottawa was talking skip on 3 watts. Got me interested. I'm ordering some 3/4" aluminum tubes and some supplies to make my own Moxon using HomerBB's schematics. It looks simple enough and a good way to pass the time. :r&r:
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
PA629
Re: Moxon beam
Post by PA629 » Friday, 13 January 2017, 4:27 AM
Decent forward gain and a great F/B ratio for a couple spreaders and 2 pcs. of wire. I've made a couple for temporary field day usage.
Base: Galaxy DX2517, D104 Silver Eagle w/W2ENY element, SB 220, Imax 2000, 4 element quad
Mobile: Galaxy 95T2, Astatic 575-M6, Sirio P-5000 Performer, Unmentionable 4x2879
Re: Moxon beam
Post by MDYoungblood » Friday, 13 January 2017, 5:35 AM
Maybe if you get the one working for you then you can try this,
Radio: Uniden/Icom/Cobra
Re: Moxon beam
Post by 231 » Friday, 13 January 2017, 11:51 AM
MDYoungblood wrote:Maybe if you get the one working for you then you can try this,
Sweet...a dual polarity. I've made one of those and it worked terrific.
I used copper tubing on mine vs. aluminum. I simply soldered 90* elbows and kept me from having to bend the aluminum. I have tubing benders but all the stuff I used on mine were bought at my local Home Depot & Ace Hardware stores. Awesome F/B & F/S ratio at any height. I will tell you that the vertical calculator is off some on the moxon antenna project calculation tool...but the Moxon is one of the best small beams I've ever had the pleasure of using. Even wire elements (which I've made several of for different bands) work very well...but not as well as tubing.
Good luck.
231
HomerBB
Radio: DX88HL
Re: Moxon beam
Post by HomerBB » Monday, 13 February 2017, 22:22 PM
Love the Moxon.
After 2 years of faultless performance in the air I just brought it down to use its mast for testing another antenna.
A friend obtained a 1970's Cushcraft CR-1 Ringo antenna and wanted me to try to get it to tune up. I did, and it does. I had to make another stub for it, but it works quite well.
Back to the Moxon.
I agree that the tubing Moxon out performs the wire versions i built. Its an easy to build small beam that never dissappoints,
Last edited by HomerBB on Monday, 13 February 2017, 22:56 PM, edited 1 time in total.
It's Not Crazy, If It Works
The 11 Meters MacGyver
Mtn Lynx
Re: Moxon beam
Post by Mtn Lynx » Monday, 13 February 2017, 22:32 PM
Weather has not been cooperating and I have not found the time to start on the antenna yet. The days are getting longer, and hopefully warmer soon. It's been in the - degrees below zero for awhile. the plan to construct the Moxon is still going to happen.
Thanks HomerBB
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
HomerBB
Radio: DX88HL
Re: Moxon beam
Post by HomerBB » Monday, 13 February 2017, 22:59 PM
:icon_e_smile:
Mtn Lynx
Re: Moxon beam
Post by Mtn Lynx » Friday, 10 November 2017, 1:08 AM
Had trouble finding scraps for the build. So ordered a Mfj 1890, it came today. When weather permits I will set it up.
[ Post made via iPad ] Image
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
HomerBB
Radio: DX88HL
Re: Moxon beam
Post by HomerBB » Friday, 10 November 2017, 6:40 AM
Re: Moxon beam
Post by MDYoungblood » Friday, 10 November 2017, 9:01 AM
Good luck.
231
Yes the vertical dimensions are shorter because the antenna is seeing the metal mast and the coax from both.
Re: Moxon beam
Post by MDYoungblood » Sunday, 12 November 2017, 13:26 PM
Now the dimensions are slightly longer for 11m.
Mtn Lynx
Re: Moxon beam
Post by Mtn Lynx » Sunday, 12 November 2017, 22:25 PM
Thanks MD, I saw a fella on YouTube set one up for 11m. His measurements were hard to read. I think he was 3/4 inch more at each corner
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Re: Moxon beam
Post by MDYoungblood » Monday, 13 November 2017, 6:28 AM
You could try this calculator, the tubing average is around 13mm (1/2") so put that in the "Wire Dia." then just add the center frequency you want to use.
MichaelPanny
Home Phone: 86744568753
Cell Phone: 89381957356
Moxon beam
Post by MichaelPanny » Tuesday, 24 July 2018, 10:19 AM
Can’t you cut the adjusters off the the beam, rotate them and re weld them on again?
Re: Moxon beam
Post by MDYoungblood » Wednesday, 25 July 2018, 16:38 PM
Need a little more info on what adjuster's you are talking about?
3'
Mtn Lynx
Re: Moxon beam
Post by Mtn Lynx » Tuesday, 31 July 2018, 23:07 PM
Man, i haven't got around to installing the moxon yet. It's just sitting in storage as a future project. It'll get up b4 next solar maximum. Lol
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
