looking for help with maco 3
wildcat374
Mud-Duck Sr.
Mud-Duck Sr.
Cell Phone: 8282016103
Post by wildcat374 » Saturday, 12 August 2017, 18:04 PM
when you are on the vertical side of the beam do you have to for each direction or is it all directional on the vetical.
Re: looking for help with maco 3
Post by MDYoungblood » Saturday, 12 August 2017, 18:55 PM
With a 3 element beam you talk and hear best in the direction it is pointing. Vertical polarity is best for base to base or base to mobile, is the horizontal polarity it is best for talking skip or another base with the same polarity.
wildcat374
Mud-Duck Sr.
Mud-Duck Sr.
Post by wildcat374 » Saturday, 12 August 2017, 19:20 PM
when you are on the vertical side of the beam do you have to turn it to hear in all directions or is it all directional on the vetical.
(edited by MDY, removed quote)
wildcat374
Mud-Duck Sr.
Mud-Duck Sr.
Post by wildcat374 » Saturday, 12 August 2017, 19:40 PM
sorrry my first post was not right......... when you are on the vertical side of the beam do you have to turn it in all directions to hear and transmit.... or is it all directional on the vetical. side where you dont have to turn it to talk all over from bass to bass.
Post by MDYoungblood » Sunday, 13 August 2017, 4:53 AM
You will still be able to hear signals around you but they won't be strong, best signal is where the antenna is pointed. If you need a manual for the antenna here it is; http://macoantennas.net/files/M103C_2011.pdf
narfedwards1
Radio: Browning Golden Eagl
Antenna: Antron 99@25'
Post by narfedwards1 » Sunday, 13 August 2017, 5:54 AM
The end of the beam with the director...shortest element is your front end
[ Post made via Mobile Device ] Image
Post by MDYoungblood » Sunday, 13 August 2017, 7:32 AM
Yes
wildcat374
Mud-Duck Sr.
Mud-Duck Sr.
Post by wildcat374 » Sunday, 13 August 2017, 11:34 AM
ok thanks... i guess i will get a another A99 my 20 year old A99 broke to pieces when i took it down and not put the beams up if you have to turn them and also they have to be in 36 foot up to be in the wave lenghth..... i have a 20 foot pole for the A99 that 38 feet from the ground to the top of the A99 will that work...
Post by jessejamesdallas » Sunday, 13 August 2017, 14:14 PM
It will work (20' pole) but when they are talking about being up in the air 30+', they are talking about where the base of the antenna is at...not the tip... So, a 20' pole will work "OK", but higher the better.
The whole antenna radiates signal, not just the tip.
wildcat374
Mud-Duck Sr.
Mud-Duck Sr.
Post by wildcat374 » Sunday, 13 August 2017, 20:55 PM
ok from what i read the super penetrator is a real good antenna the a99 is not bad which one you think is the best . thanks for your all help...
Post by jessejamesdallas » Monday, 14 August 2017, 3:05 AM
Never had either...(have a MaCo shooting star beam) but your comparing a $50 antenna to a $150 antenna...I'm leaning towards the Penetrator being the best of the two, if for no other reason, it's made out of aluminum which will out last fiberglass, plus it comes with ground radials...Just cost 3 times as much...
Post by MDYoungblood » Monday, 14 August 2017, 4:35 AM
I would go with the HyGain Super Penetrator 500 over the A99 any day of the week. They are a little more complicated to assemble but once the together right they are an awesome antenna.
