4 Pin to 5 Pin Adapter On Uniden Grant XL
- Tx1Tek
- Real Name: Billy
- Antenna: Solarcon A-99CK 17'
- Radio: Grant XL 40 CH CB SSB
Hi everyone.
I just joined the board. I used to sideband from Alaska when I lived there in the 70s in Fairbanks, but been out of it for quite some time. I have a Uniden Grqnt XL I'll be using as a base and mobile for now. I purchased a 4 pin Astatic mic and didn't realize my radio is a 5 pin. would it work to get a 4 pin to 5 pin adapter, or will I be missing something?
Re: 4 Pin to 5 Pin Adapter On Uniden Grant XL
Hello Tx1Tek,
Welcome to the forum. It's your choice, either the adapter or rewire the mic to a 5pin plug, I prefer the latter because the adapter hanging out the side is easily broken off. Just ask for the pin out. As a new member can you post a intro in the "Welcome to the Forum" topic, http://www.cbradiotalk.com/viewforum.php?f=89 , so others can say "Hi", thanks.
- battyice
- Handle: Robert
- Real Name: Robert
- Antenna: Tram 1498
- Radio: Uniden 980SSB
Hello. If you are not comfortable wiring on a new plug, an adapter will work fine. I have an adapter on my Uniden Washington.
[ Post made via Android ]
Station 731, Northern NY
-Robert
-Robert
- Blue Ox2
- Handle: Blue Ox
- Real Name: Mike
- Call Sign: KC3LAV
- Antenna: DR-Dipole, Copper "J"-Pole, IMax 2000, MFJ 1740, and a "Slinky" 40M dipole
- Radio: President McKinley&Washington+142GTL Direct Injected by Leadfoot Labs
Howdy Tx1Tec,
Sure thing, I use an adapter on my President Washington with the Silver Eagle and
I have an adapter jumper cable on my Cobra 142 GTL with the Night "K" Eagle.
They work wonderfully.
73,
Mike
73,
Mike
How do you do from Blue Ox2
KPA223 on the Galaxy DX 2517
- dgbacb4148
- Real Name: David g.
- Antenna: shakespere Big Stick
- Radio: Uniden Washington
Welcome to CBRT, glad to have you. As before mentioned, either way will work great for you. Good luck.
David g..................
AKA Southwind,Tripple Nickel, DX 555. Base station Uniden Washington Philippines made/ D-104 Tug 9/ Silver Streak 150/ Pyramid Gold Series Variable 26 amp through "Old Reliable Shakespeare Big Stick"... Mobile- Cobra 25, NMO Firestik. USAF 1959-1963/ Andrews AFB, 1001st Transportation Squadron, Maryland, home of AIR FORCE ONE. John F. Kennedy Presidential Innaguration parade 1961.
- 973Kid
- Real Name: Marc Johnson
- Antenna: A-99
- Radio: Pierce Simpson and S
I had about the same question in my mind. My favorite mic id my d-104 power mic and I have 2 radios now that I will be using. Eventually I will get a Galaxy Saturn or Cobra 2000. I don't really want to buy a d-104 for each radio so I was curious if I could get/make adapters to use the 5 pin Astatic on my other radios. I'm not near my Guardian but I'm thinking it is a 2 pin.
[ Post made via Samsung Galaxy S5 ]
