Turner +2 Lo Modulation
Microphone Information Wiring etc, or if you just need help with choosing a good microphone for your radio.
cabo316
Radio: 2000GTL&138XLR
Antenna: Imax 2000
Post by cabo316 » Tuesday, 22 March 2016, 14:13 PM
Have a +2 that was in box for many years. It was free with a radio, and never worked. With help from CBRT I set in to rebuild the interior. It was a nest of different color wires, many disconnected, and lumps of solder, mostly cold joints. So I rewire and clean with deoxit and reassemble. I am planning on giving this mic to a local club member who has a 2547 with a hand Astatic...so I wired it as a 4 pin. I use a 5 pin +3 on my base. I hooked the +2 with 4 to 5 adapter to my base. I'm getting reports from the locals who know my +3 Tx volume, and I'm told the +2 has low modulation...not "good sound" like the +3. Turning up the pot beyond 11-12 it starts to squeal. There is an amp board up where the mic element is and another where the mod pot is. Is it time to rebuild the board(s). I can't in good conscience give this away with low mod. Thank you for suggestions.
Logged in via: iPad
Re: Turner +2 Lo Modulation
Post by MDYoungblood » Wednesday, 23 March 2016, 12:14 PM
I'd try it on a Cobra, Galaxy, or Uniden radio first to see if the problem is the adapter. Check your wiring so nothing could be shorting. There is only one electrolytic cap that possibly go bad or dry out which would be the case here. Only other thing is the mic element itself is bad.
Base
Uniden Washington
Mobile
Texas Ranger TR-696FD1C
Handheld
Maxon HCB-40WX
Antennas
Avanti Sigma II
Homemade Full Wave Loop
Homemade 1/2 wave Dipole
cabo316
Antenna: Imax 2000
Post by cabo316 » Saturday, 26 March 2016, 10:51 AM
MDYoungblood wrote:I'd try it on a Cobra, Galaxy, or Uniden radio first to see if the problem is the adapter. Check your wiring so nothing could be shorting. There is only one electrolytic cap that possibly go bad or dry out which would be the case here. Only other thing is the mic element itself is bad.
Thanks Greg. I opened up the mic, again, and checked wiring with schematic. It looks right. Put it back together again and got the same local guy to respond...sounds like you're in a large tin box...low modulation...very "tinny" sounding. Really good needle swing on my meter as well as his. He suggested same thing, mic element may be bad. I thought I had another +2 in my possession, but haven't unearthed it yet. Have done the online search for a mic element, with no luck. Also, I know in the old days, the remedy for too much bass? was to poke a hole in the foil part of the element. That was done decades ago, as I didn't do it and I've had it for 35? years. For now it will be "on the side".
Logged in via: iPad
Post by MDYoungblood » Saturday, 26 March 2016, 15:48 PM
I hope you can find that donor mic, if not any pickup element would work, check out some yard sales or flea markets and find a recording mic (kids toy mics), some I've found have some really excellent ceramic and dynamic elements in them. won't be much if anything to change in the amplifier board, might need to put a .01 cap across the pickup leads.
Base
Uniden Washington
Mobile
Handheld
Maxon HCB-40WX
Antennas
Avanti Sigma II
GS19D3
Mud-Duck Sr.
Mud-Duck Sr.
Radio: Anything Cybernet
Antenna: Phased dipoles
Post by GS19D3 » Monday, 13 June 2016, 19:58 PM
I know it is an old post, but I'd love to know how this one turned out. The ceramic element in the Turner mics is really robust. On the off chance the element is bad, you can sub a ceramic element from any old 23 channel Johnson CB. Sounds like either the FET impedance convertor on the back of the mic element, or a leaky cap on the amp board. I have a couple of +2s here. Great mics.
