Cb microphones
- smoke blower
- Handle: East coast broadcaster
- Real Name: David Sadler
- Radio: Cobra 2000
Cb microphones
I have a hard time with mikes 80% of them I try everyone says that there basey sounding which I have tried Turner+3 , silver eagle, astatic echomax 2000, and different astatic mikes is there something I can do to change that. Oh I tried each of them on different radios with same out come.
- jessejamesdallas
Re: Cb microphones
You tried a D 104 and it sounded basey?
Usually they tend to sound tinnie....
- smoke blower
- Radio: Cobra 2000
Re: Cb microphones
I have a silver eagle but I don't like that Mike it picks up every noise in the back ground. I have a friend that has a Turner +3 which I have be sounds top shelf I hooked mine up to a cobra 25 like he did and everyone says its basey what can I do to change that. And yes the silver eagle sounds tintty the d104 hand Mike sounds real Tintty also. I would give anything to have a great studio sound I have paid alot of money for all different mikes people have said are the best sounding mikes but for me they sound bad trying to figure out what to buy or what to do to change this.
Re: Cb microphones
What radio is it hooked to? Try turning the gain down on the mic and up on the radio.
- smoke blower
- Radio: Cobra 2000
Re: Cb microphones
I hooked it to a Galaxy 2517, Galaxy 66 , and a Uniden grant and all the same outcome. What would be a real good mike that has good studio sound to it
- jessejamesdallas
Re: Cb microphones
I don't think your problem is with your Mic's, but more with CB Radio and what your wanting it to sound like. To get that studio-sound like your talking about you need something like Pro Tools or a mixer like you would use in music recording. A good Mic is part of it too, but you could spend hundreds of dollars on a Mic, and they would still not have a studio quality sound on a CB Radio without having something else inline to help the radio broadcast the way you want...Plus, if your radio has been peaked & tweaked to get every drop of watts out of it, there's not much of anything your going to be able to do to get a quality sound out of it.smoke blower wrote:I hooked it to a Galaxy 2517, Galaxy 66 , and a Uniden grant and all the same outcome. What would be a real good mike that has good studio sound to it
- Real Name: Darryl B
- Antenna: Imax 2000
- Radio: 2000GTL&138XLR
Re: Cb microphones
Is this friend close enough to go to his location? I think I would ask to try your mics on his equipment. If his +3 sounds proper, yours should sound the same at his location. If you DO find an answer, post it up...I'm getting ready to go thru the same check and eval on my +2 and +3 after having them in boxes for tooo long, and reinstalling my base station.smoke blower wrote:I have a silver eagle but I don't like that Mike it picks up every noise in the back ground. I have a friend that has a Turner +3 which I have be sounds top shelf I hooked mine up to a cobra 25 like he did and everyone says its basey what can I do to change that. And yes the silver eagle sounds tintty the d104 hand Mike sounds real Tintty also. I would give anything to have a great studio sound I have paid alot of money for all different mikes people have said are the best sounding mikes but for me they sound bad trying to figure out what to buy or what to do to change this.
- smoke blower
- Radio: Cobra 2000
Re: Cb microphones
Yes I can try that
- Slim Pickins
- Handle: Slim Pickins
- Real Name: Paul
- Call Sign: VE1PEW
- Radio: Realistic Navajo 457
Re: Cb microphones
Have you tried using a computer mic and sound out from your computer's sound card with an interface device to the mic on the radio. There are tons of audio mixing programs out there that use programs (plug ins) that can be used to tune the audio using your computer. Then you can plug into the mic socket using an interface. I played around with this and a dollar store computer mic and had food results and a lot of fun.
73,Slim
- smoke blower
- Radio: Cobra 2000
Re: Cb microphones
Do you think maybe you could message me on some of the info I could use and exactly what I need If you don't mind
- Rabbit Ears
- Handle: Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
- Antenna: Hygain Penetrator 500
- Radio: RCI 2995DX CF
Re: Cb microphones
Have you tried the Turner Super Sidekick?? *It is more natural sounding*
I know well of your plight.... For years I used a Marantz stereo equalizer to cut the crud out and add a little more where the microphone was lacking.
Still, the Turner SSK.... COOL!! I got one. The turner SSK has a much softer and deeper tone for voice on side band. And it has the "punch" on the AM and FM modes too.
USA FOREVER
RCI 2995DX CF (PRIMARY BASE)
Turner Super Side Kick
RM Italy KL300P (A/B modded) in truck
BIRD 43P
HY-GAIN SPT-500 antenna
BIRD 43P
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
Re: Cb microphones
Smoke Blower I know you do not have a deep voice to cause this so that is out. are you by chance in a room that is causing some harmonics or echo sound when you talk? a buddy of mine years ago converted his garage to a radio room and he had a deep hollow sounding voice on his base radio. after he put some furniture in it and carpet on the floor his voice was back to normal. with some of the mics you are trying should give you a tinny higher pitch voice when you talk, such as the D104 base mic. not sure what is causing you to have this problem on ever radio you try themj on. so even changing caps inside the radio is not the way to solve the problem.if I think of some thing I will let you know. I have been thinking about this ever since you started the post.
- smoke blower
- Radio: Cobra 2000
Re: Cb microphones
OK that will be great and my shop has alot of furniture in it also has carpet on the floor so I am not sure but alot of people say my voice is basey sounding the only two mikes I can use that isn't is a Uniden bear cat and a newer style Galaxy mike
- sonoma
- Handle: sonoma
- Real Name: sonoma
Re: Cb microphones
you might try a 101 to 103 disk cap across the mic element connectors and see if one of them will help. one of the 3 might help. just not sure where to go with this one.
- smoke blower
- Radio: Cobra 2000
Re: Cb microphones
OK like to both wires on the element it self I guess what you are saying is just jump the element with the cap
- sonoma
- Handle: sonoma
- Real Name: sonoma
Re: Cb microphones
just try across the 2 wires at the mic and see if it helps any. may kill the audio completely but try a lower value if it does. never seen this problem before. are you sure some one is not just messing with you. never heard a D104 basing sounding.
- Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
Re: Cb microphones
If you do use a D-104... you can use these things *provided that you are handy with a soldering iron*
They have hi fi upgrade kits for your D-104 to replace your mic element. It really kicks butt too, if you love your lollipop.
It is a never-ending quest; oh so I do remember
USA FOREVER
BIRD 43P
BIRD 43P
Re: Cb microphones
A D104, which stand model doesn't matter would give those radios there best audio, the trick to a D104 is to adjust the mic's gain just enough to produce a quality sound and not pick up all the background noise or the hash sound from being turned up too high, that is the biggest mistake made when using a D104. Another thing that works well is changing the crystal or ceramic mic element and convert it over to a electret mic element, these elements are used in studio mics and give the D104 a more natural sound, again as long as it's not turned up to the max.
