DIGITAL POWER/SWR METER
- dgbacb4148
- Real Name: David g.
- Antenna: shakespere Big Stick
- Radio: Uniden Washington
Any suggestions what is best bang for the buck ?
Re: DIGITAL POWER/SWR METER
Check out the LP-100A Digital Vector Wattmeter, get the 2 channel just in case you want to add VHF/UHF, be prepared for price shock.
There were a few companies in the past that had a led bar for SWR and power, Palomar M-827 was one, Palomar had others too, you'll see them on that auction site once in a while and Bombero made a post about one by MFJ, http://www.cbradiotalk.com/vi ... =5&t=48167 , looks interesting.
- Scholar
- Real Name: John ODonnell
- Antenna: Sirio Tornado
- Radio: RCI-2995
Scholar (John)
KEB7787
"7787" ---- 38 lsb
Base
RCI 2995DXCF ---- MFJ-299Mic ---- Sirio Tornado 5/8 Wave Antenna
Galaxy DX2547
Mobile
RCI-2950DX ---- Wilson 1000 Antenna
KEB7787
"7787" ---- 38 lsb
Base
Galaxy DX2547
Mobile
I do like that one and the one with an analog meter only thing wrong is I would like to see them make it 6 digit on the frequency counter.
- Bluerunner
- Handle: BlueRunner
- Real Name: Mike
- Antenna: Starduster
- Radio: Cobra 142
Digital is good for some things, like a digital multi meter, when measuring a steady state.
However when you are measuring something that changes such as power under modulation or varies due to power supply drop analog can't be beat.
- Rabbit Ears
- Handle: Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
- Radio: RCI 2995DX CF
I have a vintage Hickok digital I use. But I'd rather use a BIRD. *wink*
I've seen digital wattmeters fry!
USA FOREVER
RCI 2995DX CF (PRIMARY BASE)
Turner Super Side Kick
BIRD 43P
HY-GAIN SPT-500 antenna
BIRD 43P
- Scholar
- Radio: RCI-2995
I have both digital and analog. I really prefer the analog. Both are accurate and both have there pro's and con's. Analog, to me is better when using side band.
Scholar (John)
KEB7787
"7787" ---- 38 lsb
Base
Galaxy DX2547
Mobile
KEB7787
"7787" ---- 38 lsb
Base
Galaxy DX2547
Mobile
- Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
You said it! *grin*
USA FOREVER
BIRD 43P
BIRD 43P
