hf rig noise
A place to ask questions about base setup for CB radios or HAM radios. Talk about your experiences, seek advice, and share knowledge.
dirtyjob
Handle: dirtyjob
Real Name: Mark
Antenna: Super Penetrator 500
Radio: Many
hf rig noise
Post by dirtyjob »
ok i have a few radios and antennas i use daily for base operations, i have noticed that when i have a cb hooked up to any of my antennas "ofc windom/ spt500/3 element gizmotchy" they run normally with little backround noise as they should during normal conditions.. However, if i use any of my hf rigs such as say my kenwood 870s, with my spt500 or 3 element gizmotchy i get 9 s units of static, but if i hook the hf rigs up to the ofc windom dipole it goes away.
My question is why do the other 2 antennas give me so much noise and the windom does not ?
P.S. Sometimes, not as often as i would like, the 9 s units of noise is not there.
"LISTEN FOR THE PING"
Gizmotchy G-31 Beam
Super Penetrator 500 5/8 Wave
Comet GP9 2 meter/440
CBRT 18204
Re: hf rig noise
Probably polarity, do you get the S9 on the horizontal side of the beam? That is a very high noise level, I would be searching out what's causing it, mother natural rarely gets that high.
231
Re: hf rig noise
Greg might be right...it could be something as simple as polarity issue. But it sounds like you are running the Pre-Amp on the TS-870? If so, shut it off. I never run Pre-amps as all they do is amplify noise. If you need to pull stations out from the noise invest in a Times Wave ANC-4 noise phaser (or the MFJ version). They really do work.
Are you running any odd wall warts with the Kenwood by chance or move it close to say a USB hub on your comuputer? Are you sure it's actually the antenna(s) causing the noise? Lost more questions than answers...sorry.
231
Owner
Owner
Handle: Bozo
Real Name: James Wadsworth
Antenna: Monkey Made MM9
Radio: General Lee Radio
Re: hf rig noise
Post by »
Great answer Larry
Posted from the Bozo Phone
http://www.circusmobile.com
Donate here
Slim Pickins
Handle: Slim Pickins
Real Name: Paul
Call Sign: VE1PEW
Radio: Realistic Navajo 457
Re: hf rig noise
Post by Slim Pickins »
I quieted an S9 noise from my HF rig by moving the antenna rotator control further from it. I think the transformer was causing the interference. I didn't have it on my tube rig but it was torture on my iCom.
73,Slim
Insanity is hereditary......you get it from your children.
Deleted User 14541
Re: hf rig noise
Post by Deleted User 14541 »
On 10 &11 meter AM the noise bkanker/anl in my CBs seem to be better than my kenwood ts440 and yaesu 1200. The yaesu is alot quieter than the kenwood but sometimes I still get electrical noise that isn't there with a 148.
pabxone
Re: hf rig noise
Post by pabxone »
Try temporarily patching thru a hard earth from a reliable earthing point on to the metal chassis of the radio.
Try to pick up a nice clean earth from the closest metal water pipe that heads off into the ground that also preferably doesn't have a bonding connection to the buildings MEN earth cable running back into the buildings mains power earthing.
Even an old piece of galvanized iron or copper water pipe hammered 4ft or so into the ground would be a good enough earth for a test to see what effect it has.
If that fixes it a single stainless steel earthing rod (2 rods will be needed most likely if you have sandy soil) with a 16mm earth cable back to the radio with a proper earth clamp at the rod end and a decent eyelet connector at the radio end should be the fix.
If that's still no better - If you have any lightning protection at the mast - try temporarily disconnecting that to see if it has any effect (Possible corrosion in the lightning arrestor , corrosion / LIR in the plugs or sockets , blown arrestor from a lightning strike and/or poor earth (Even foreign earth relative to the earth reference at the radio) at the arrestor.
Try temporarily hard earthing the mast from the same hard earthing point as before (Even try this if the antenna is a supposedly "Ground independent" variety)
Try also powering the equipment off a battery only - even a low current gel cell for a short RX only noise test - noise could be traveling back thru the mains supply , building cabling and/or internally generated within a power supply.
73
Mark
