Can't find any info on Realistic TRC-455
- Radio: Realistic
Hi all! New to the site and new to base stations. I'm glad I found this site. Lots of good stuff here. I have a few basic questions for those of you in the know.
I have been using basic CB rigs in my vehicles for the past few years, but I don't know much about them other than hooking them up and calibrating the SWR. I have been wanting a base station for a few years, but never knew what to buy. This morning I stopped at a garage sale and found a Realistic TRC-455. It appears to be in great condition and came with an operating manual. I plugged it in for a few seconds to see if it worked and briefly keyed the mic. It all checked out so I bought it for $20. I haven't had much luck finding any information or reviews on it so any help there would be great.
My wife and I own an 18 acre camp (as we call it) that we stay at on the weekends. She frequently takes her golf cart down to the creek which is about a mile away through the woods. My plan is to setup a base in the cabin and hook a mobile unit in her golf cart in case we need to contact each other. The walkie-talkies don't work because the woods are too thick and the terrain is too rugged. I'd also like to use the base when we travel to the local store a few miles away and for the occasional rainy day to pass some time talking with a stranger.
Now for the questions.
I know I need a coaxial cable, but is there a certain kind? My manual says an impedance of 50 ohms and suggests RG-58/U for short lengths and RG-8/U for long lengths. I don't know what that means or know if that type of cable still exists today! Do I want short or long?
What type of antenna should I get? I have seen a few different styles and don't want to get the wrong kind.
How/where do I mount it? We are surrounded by trees! o I simply mount it as high as I can on the roof of the cabin?
I read in the operating manual something about needing a FCC Class D license. Do I need to get that?
- dirtyjob
- Handle: dirtyjob
- Real Name: Mark
- Radio: Many
Re: Can't find any info on Realistic TRC-455
I know I need a coaxial cable, but is there a certain kind? My manual says an impedance of 50 ohms and suggests RG-58/U for short lengths and RG-8/U for long lengths. I don't know what that means or know if that type of cable still exists today! Do I want short or long? : Use what you need to make the run from antenna to radio, most use 50feet some use 75 feet and others use 100feet, totally depends on how long the run requires, rg8x is what i use, its well shielded and flexable and doesnt cost an arm and a leg.
What type of antenna should I get? I have seen a few different styles and don't want to get the wrong kind. - most likely want an omni directional, something like an antron 99 or a imax2000 will work well and again is cost effective.
How/where do I mount it? We are surrounded by trees! o I simply mount it as high as I can on the roof of the cabin? Throw in on the roof/ in a tree or on a tower. Get it as high as you can for best results.
I read in the operating manual something about needing a FCC Class D license. Do I need to get that? - NO
"LISTEN FOR THE PING"
Gizmotchy G-31 Beam
Super Penetrator 500 5/8 Wave
Comet GP9 2 meter/440
CBRT 18204
Gizmotchy G-31 Beam
CBRT 18204
- Radio: Realistic
Thank you! I will start the hunt for the items you suggested.dirtyjob wrote:I know I need a coaxial cable, but is there a certain kind? My manual says an impedance of 50 ohms and suggests RG-58/U for short lengths and RG-8/U for long lengths. I don't know what that means or know if that type of cable still exists today! Do I want short or long? : Use what you need to make the run from antenna to radio, most use 50feet some use 75 feet and others use 100feet, totally depends on how long the run requires, rg8x is what i use, its well shielded and flexable and doesnt cost an arm and a leg.
I read somewhere that with a directional antenna, I may need a rotating base or something like that. Is that correct?
-- Saturday, 25 April 2015, 19:18 PM --
I started reading more about antennas and answered my own question. I have located the items and will be assembling my base when the components arrive. I'll let you know how it works. Thank you!
Hello fletchman919,
No, no more licensing for CB by the FCC and I would key the mic anymore without a load (antenna or dummy load). For the base station the antennas dirtyjob suggested are good or if you have the room a good ground plane like the HyGain super Penetrator 500 would be excellent, a beam might come into play but after you get use to the radio and such. A small cobra 19 or such will work on the golf cart, that is on most of the carts at my campground. I would use RG8 or RG213 for the base antenna coax. To mount the antenna you could use a tripod on the roof or a pushup pole on the side of the cabin, a tower is nice but the cost is high.
After you get setup then we can help some mods to the radio, make that another topic.
As a new member could you post a intro in the "Welcome to the Forum"topic, http://www.cbradiotalk.com/viewforum.php?f=89 so others can say "hi", thanks.
- Radio: Realistic
Awesome! I will look into the ground plane antenna you mentioned. Not sure what a beam is yet, but I'll try to figure it out.MDYoungblood wrote:Hello fletchman919,
As a new member could you post a intro in the "Welcome to the Forum"topic, so others can say "hi", thanks.
The Cobra 19 is exactly what I was planning on using in the golf cart. It's the same radio I've been using in my truck for the past few years. It's very basic but it does the job I need it to do and is small.
I'm glad you mentioned mods as that's something I'd possibly like to do in the future.
I'll post an intro now. Thanks you!
- Radio: Realistic
I am having some trouble choosing an antenna mount. I decided to go with the imax200 and need some help choosing the correct mount. I'm not sure if I'm looking at mounts that will work. Would someone post a link to a mount that is compatible with the imax2000?
Also, our cabin is made out of metal siding and roof. Will this be a problem?
- Buzzweiser
- Handle: Peacemaker
- Real Name: Dave 656
- Antenna: Performer 5000
- Radio: Custom Built 2970N4
Since you have a metal building and roof you'll want to get the base of the antenna above the roof line for best results. At minimum 1/4 wave length(about 9') but again the higher the better.
- Radio: Realistic
Okay, so do I need a tower? I was hoping something more wallet friendly.Buzzweiser wrote:Since you have a metal building and roof you'll want to get the base of the antenna above the roof line for best results. At minimum 1/4 wave length(about 9') but again the higher the better.
- Bombero
- Handle: Boogieman
- Real Name: Bombero
- Antenna: 2ft Wire hanger
- Radio: RCI 2950 Mirage
Hey..fletchman919 wrote:Okay, so do I need a tower? I was hoping something more wallet friendly.Buzzweiser wrote:Since you have a metal building and roof you'll want to get the base of the antenna above the roof line for best results. At minimum 1/4 wave length(about 9') but again the higher the better.
You don't really need a tower.
Google 'Tilt Base Antenna Mounting System' or put 2 or 3 sections of top fence railing together...enough to get your antenna over the roof line.
Bombero
383 Boogieman
- Radio: Realistic
Okay, thanks Bombero!Bombero wrote:Hey..fletchman919 wrote:Okay, so do I need a tower? I was hoping something more wallet friendly.Buzzweiser wrote:Since you have a metal building and roof you'll want to get the base of the antenna above the roof line for best results. At minimum 1/4 wave length(about 9') but again the higher the better.
Bombero
With a metal roof the best antenna for you is going to be one that has ground plane radials, the Maco or HyGain would work well, any metal under the plane is irrelevant. No you really don't need a tower , a good tripod will do, good ones aren't cheap but made to hold quite a bit and some are laddered to climb up to the antenna. Optimum height for a CB antenna is 36ft but not necessary.
