cobra 142gtl
- 299 Georgia
- Mud-Duck Jr.
cobra 142gtl
Hello everyone, I have cobra 142 gtl and it needs a ac power supply. I need some help with a part number or where I could possibly buy one. Thanks for the help in advance.
- Handle: Boogieman
- Real Name: Bombero
- Antenna: 2ft Wire hanger
- Radio: RCI 2950 Mirage
Re: cobra 142gtl
383 Boogieman
Re: cobra 142gtl
A big hello 299 Georgia, as op showed you a link to forum sponsor's, go to Gi Joe's on the right side of the sponsor page, click on their home page, on the l/side go down to power supplies. My suggestion is the third one down with two meters. It has one for amps and one for volts. PS 26 KX (1710) This will handle what your looking for now and in the future, if you buy a small one and later decide to run an amp, it will not do the job. JMHO and good luck from one Georgia Dawg to another, 3's to you/yours, and have a good evening.
- ogdoa
- Real Name: Rob 151
- Antenna: Maco v5000/102"
- Radio: Cobra 2000/RCI2970
Re: cobra 142gtl
I am not sure but I think he is looking for the internal power supply. I have had this problem before with them burning out and it is just easier to run an external IMHO. They seem to run better on the external supplies for some reason. Maybe one of the techs on this site can explain why. If you are dead set on getting the internal working...try to find a parts radio to salvage one from. They are pretty easy to find.southwind wrote: A big hello 299 Georgia, as op showed you a link to forum sponsor's, go to Gi Joe's on the right side of the sponsor page, click on their home page, on the l/side go down to power supplies. My suggestion is the third one down with two meters. It has one for amps and one for volts. PS 26 KX (1710) This will handle what your looking for now and in the future, if you buy a small one and later decide to run an amp, it will not do the job. JMHO and good luck from one Georgia Dawg to another, 3's to you/yours, and have a good evening.
Sometimes you feel like a duck....sometimes you dont.
151 FRIED CHICKEN
Branson, MO
Home channel
26.845
151 FRIED CHICKEN
Branson, MO
Home channel
26.845
Re: cobra 142gtl
I would first hook it up to a external power supply to determine that it is indeed a bad internal supply. Does it hum when turned on? Several different things could be wrong with it, the big cap, regulator, the on/off switch, might even be a bad internal/external switch on the back.
