I wasn't having much luck with dx today so I decided to make an air choke which can be easily removed and reused on my next antenna (future moxon).
With the bad connector on the coax, I had no issue with cutting it off. I soldered the shield to one bolt and the conductor to the other. I drilled holes and elongated them towards the direction I was to wind the coax. This kept any sharp bends to a minimum.
2 inch pvc tube
1 - 2 inch cap
18' of rg8x (had a bad end)
2 - 1/4" bolts with washers and nuts
2 - eyelets for wire connections
One step closer to my moxon
- poboy309
- Antenna: 102" whip
- Radio: Grant lt
Uniden Grant LT barefoot mobile with a 102" whip.
President Lincoln "base" in the garage with a home made horizontal dipole.
36 - 40 lsb
RC 309 in hellinois.
36 - 40 lsb
