Base Station Build
kuppler
Handle: Explorer
Real Name: Adam
Antenna: Stryker SR-A10 Magnetic Mount Antenna
Radio: Stryker SR-447HPC2
Base Station Build
#360682
Post by kuppler »
Well i want to have a base station but didnt want just a mobile radio chilling on a desk. Didnt have the cash flow to get a base station so im going this rout.
THE CASE
The radio ill be installing into the case.
Galaxy DX 959
also picked up a few volt meters to install in the case. So i know what the Power supply is pushing and how much power is going into the DX 959
odds and ends. like fans, fuse holders, echo/power mic ect....
I have a power supply to mount inside the case as well.
will be cutting out the front panel this weekend and mounting everything. will post in this thread with updates.
i still need to get an Amp, and an antenna. lol....
Galaxy DX 959, Cobra 29 LTD Classic, Wilson 5000
yamaha
Real Name: Mike
Antenna: A99,M103,60rohn
Radio: 2950DX--2000GTL
Re: Base Station Build
#360685
Post by yamaha »
If you don't already own one,,,, now's the time to purchase a Dremel :lol:
2950DX - 2000GTL - 148GTL - 29LTD - 19Plus - 3300HP - DX959 - Galaxy SIRIUS (some type of RCI creation)
kuppler
Handle: Explorer
Real Name: Adam
#360686
Post by kuppler »
yamaha wrote:If you don't already own one,,,, now's the time to purchase a Dremel :lol:
lol.. alrdy got one... with lots of tools/adapters for it.. lol
yamaha
Real Name: Mike
#360689
Post by yamaha »
I would trace the face plate on the box,, and go to town on it!!
231
#360695
Post by 231 »
Hey, right on. I look forward to following your posts and progress on it.
I totally understand your thoughts on wanting a bigger radio. Back in the day I drooled over 'Big Radios' until I got one. Since then I've been bothered by having a smaller radio. I think some of the best QSO's I've made was when I ran my Philly made 148GTL in the shack with my D104-TUG9 mic. Nobody could tell the difference between it an a Cobra 2000 except me. Albeit it's really nice having easy to see meters.
Best of luck
231
Radar-DLDN
Real Name: JD-
Radio: Bearcat
#360705
Post by Radar-DLDN »
Looking forward to seeing this project! Thanks for sharing!
From myHTC One via Tapatalk
#360707
I like yamaha's idea of overlaying the face plate. Here is a pic of a mobile radio that was made into a base, same idea, this Pal model was a bad radio, didn't last very long after the FCC found out it could transmit on the VFO with just the removal of a diode. It even had a built in RF preamp (+10db). If I remember any others I'll post them too, kind of give you an idea for how to go about it.
Image Image
kuppler
Handle: Explorer
Real Name: Adam
#360723
Post by kuppler »
Took the front panel off the case. measured everything out for the 959. and started cutting.. lol
all cut out for the 959.
the 959 fits just right..... :-)
got the fues plugs installed for the duel fuse power cord.
the on/off switch installed and the on/off led drilled out.
I just need to cut out the holes for the volt meters and waiting for the 4 pin mic plug to come in the mail. this base station is almost done. Ill use some acetone to get the marker marks off when im all done.
kuppler
Handle: Explorer
Real Name: Adam
#360768
Post by kuppler »
I'll be cutting out the holes for the volt meters today... I hope. Lol
Deleted User 14541
#360769
Post by Deleted User 14541 »
Looking good so for. Nice to see some custom fabrication.
kuppler
Handle: Explorer
Real Name: Adam
#360782
Post by kuppler »
543FtWorth wrote:Looking good so for. Nice to see some custom fabrication.
Thanks. Can't wait to get it finished.
High_Speed
Handle: High_Speed
Real Name: HighSpeed556
#372161
Post by High_Speed »
Hey did you ever finish this project?
HighSpeed556 in the Bluegrass
Uniden Bearcat 980 SSB
Wilson 500 (Mobile)
Homebrew Vertical Dipole (Base)
