Finally!
- Aughtry
- Handle: Aughtry 722
- Real Name: Ryan
- Call Sign: K4TXN
- Antenna: President Iowa
- Radio: President Bill FCC
Finally!
Well it finally came in. A RCI 2970N4 . 10, 11, and 12 meters. Got it hooked up and hit a few folks on 38 lsb right off the bat. A little bit of umph helps when conditions aren't so great, and really helps when it's rolling. Put it away for tonight. Need to go through the manual. Going to work 10 meters with it also. Have to use the DOSY to find where 200 is to keep within limits of a Technician. I'll be on the air!
Also got the Palomar SL41 mic. I'll keep the Astatic 636L with the Galaxy working as a base.
Oh, and it's running through LMR400 coax to a Predator BadToTheBone.
Edit: I realize the freq is off in the pic...
Aughtry 7 double-deuce waivin' atcha from Prisontown, TX
President Bill II FCC AM/FM with President Iowa antenna
Yaesu FTM-400 with Larsen NMO2/70B antenna
Yaesu FT-891 with various antennas
Tex.Proud on IG
Amateur - K4TXN
GMRS - WQZF521
Tex.Proud on IG
Amateur - K4TXN
GMRS - WQZF521
Re: Finally!
Good looking setup Aughtry, if any 10m hammie's ask you what radio your running tell them it's a Yeasu.
- silvereagle1
- Handle: Silver Eagle
- Real Name: Mark
- Antenna: Sirio Turbo 5000
- Radio: President Lincoln 2
Re: Finally!
Yep, been there done that a couple years ago. Tell them it's a yaesu you'll get a great report back.
[ Post made via iPhone ]
President Lincoln 2
Sirio Turbo 5000 Roof Mount
567 East Tennessee
567 East Tennessee
- Real Name: Joel Jennings
- Antenna: Wilson 1000
- Radio: Ranger RCI 2970N4
Re: Finally!
Great setup! I love my 2970N4, I'm sure you will also.
