Amp going backwards
- RodinKy
- Real Name: Rod Eagan
- Antenna: IMAX 2000/Maco Comet
- Radio: DX2517 & Mark IV
Amp going backwards
Varmit XL250 on low is showing backing up when I modulate, what am I doing wrong?
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
Re: Amp going backwards
Did it start all of a sudden or did you just get? How much drive are you hitting it with?
Yea, that's not a whole lot of information for us to help determine what's up.
What are you judging the modulation swing on?
Do you have a watt meter in line that's showing things?
If so what is your dead key into the amp?
What radio are you driving the amp with?
231
231
- RodinKy
Watching an inline watt meter, without modulation it is reading 125, with modulation its backing up to about 60. Dead key is 4 watts. Galaxy 2517. This is using the low power setting on the box.
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
Seems like a lot of deadkey for that little amp. I'm thinking it only needs 1.5-2w dead key.
- RodinKy
Thanks Crusher, I'll give that a try.
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
Remember, that's a 250. It's not going to do a lot. Sounds like your using a average meter as well, not a pep meter.
-- February 14 2017 --
Update? What was results?
