Midnight Special Linear
This is the place to ask questions about linear amplifiers, or power supplies
Mtn Lynx
Radio: Anytone AT 6666
Antenna: A99/Wire dipole
Post by Mtn Lynx » Wednesday, 16 November 2016, 23:36 PM
Anyone using one of these amps? I'm reading about these in 500 watts. Is it worth buying one? Just got a Palomar 225 amp. I may need to amp up. How much is too much when it comes to wattage? I've been reading that some dudes are perfectly happy skipping barefoot. I may just be too anxious to get a confirmed contact. :bounce:
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
PA629
Re: Midnight Special Linear
Post by PA629 » Thursday, 17 November 2016, 3:17 AM
It takes four times your output power to make an S-unit difference on the receiving end, so you'd be looking at roughly 1/2 an S-unit signal increase with a MS. Your first 200W is your best bang for the buck, so unless you're willing to step up to an 8-pill with all the associated system upgrades required, stick with your 2-pill Palomar. You'd be much further ahead spending your money on an antenna upgrade to something directional, if you're running the amp as a base unit. JMHO.
Base: Galaxy DX2517, D104 Silver Eagle w/W2ENY element, SB 220, Imax 2000, 4 element quad
Mobile: Galaxy 95T2, Astatic 575-M6, Sirio P-5000 Performer, Unmentionable 4x2879
rrtdave
Post by rrtdave » Thursday, 17 November 2016, 4:12 AM
Well,
My 2-cents. Use what you need. I have an OEM alternator in my Ford explorer, no extra batteries and no problems getting a signal to the NE or NW corner, CA, Georgia, the Carolina's IF there is skip available. Galaxy 979 radio with X-Force Midnight Special 700 and Predator 10k antenna.
301 Wyoming
sonoma
Post by sonoma » Thursday, 17 November 2016, 7:22 AM
mtn lynx should be on a base with a A99 antenna unless he has changed, the A99 is a pretty good antenna but a beam is far better. do not give up you can some times hear others due to the skip movement but they will not be able to hear you. I have seen times I would call back all day and never get some one. so went to a moonraker 4 and a tower and still had the same problem at times. just not as often. you can change things all day long but in the end a 4 watt radio and a antenna like you are using will get you as many reply's as a beam. right now I am using a maco 5/8 and have a A99 as a backup. so just be patient with what you have . do not just keep buying thinking you will have better luck. for years guy's have said CB stands for constant buying.
Mtn Lynx
Post by Mtn Lynx » Thursday, 17 November 2016, 11:22 AM
thanks guys, some one else won the auction anyways.
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
