I picked up a Palomar 300A..But,
This is the place to ask questions about linear amplifiers, or power supplies
Stoneman
Radio: Cobra 2000 GTL
Antenna: Dipole
Post by Stoneman » Saturday, 15 October 2016, 17:00 PM
When ya plug the power supply into the back of the amp, it's keeps poppin the fuse...Think the power supply is bad??
redlght
Radio: a few diifferent
Antenna: astroplane
Re: I picked up a Palomar 300A..But,
Post by redlght » Saturday, 15 October 2016, 19:26 PM
I would guess the filter caps are bad and maybe shorted the rectifier diodes been there this week lol
543FtWorth
Radio: (non-sponsor) 29 LTD
Antenna: *Censored*
Post by 543FtWorth » Sunday, 16 October 2016, 5:37 AM
Yep. It's likely a rectifier diode but could also be a shorted tube. If the filter caps are old replace them. A quick way to test for a shorted tube is disconnect the wires at the tops of the toobs (anode) and try it again. If it doesn't pop the fuse with all the tubes disconnected shut it down, discharge the caps and connect one tube. Keep doing this until you find the one that makes the fuse pop.
Crusher
Post by Crusher » Sunday, 16 October 2016, 5:39 AM
Agreed
bluemeanie
Radio: LOTS OF TUBES
Antenna: Max 2000 MACO M105
Home Phone: 9706253581
Cell Phone: 9709489991
Post by bluemeanie » Monday, 17 October 2016, 4:55 AM
If it doesn't pop the fuse with all the tubes disconnected shut it down, discharge the caps and connect one tube.... Yea discharge the caps. If your not familiar with the high voltage and the procedures involved. Learn them, you and your heirs could be very sorry. Just stating the obvious, it's what I do.
Blue
Stoneman
Antenna: Dipole
Post by Stoneman » Saturday, 22 October 2016, 18:59 PM
543FtWorth wrote:Yep. It's likely a rectifier diode but could also be a shorted tube. If the filter caps are old replace them. A quick way to test for a shorted tube is disconnect the wires at the tops of the toobs (anode) and try it again. If it doesn't pop the fuse with all the tubes disconnected shut it down, discharge the caps and connect one tube. Keep doing this until you find the one that makes the fuse pop.
Disconnect all 5 tubes, or just the four in the bundle??
543FtWorth
Antenna: *Censored*
Post by 543FtWorth » Sunday, 23 October 2016, 12:35 PM
Disconnect all of the tubes. Make sure the wires you disconnect aren't touching the case or any other components before you power it up. I thought there were 6 tubes in those amps. 2 driving 4.
Stoneman
Antenna: Dipole
Post by Stoneman » Sunday, 23 October 2016, 22:18 PM
543FtWorth wrote:Disconnect all of the tubes. Make sure the wires you disconnect aren't touching the case or any other components before you power it up. I thought there were 6 tubes in those amps. 2 driving 4.
Yeah I meant to say 6....I'll give it a shot this week, gotta get some more fuses...Thanks
